Pi 3, Highberry DAC HAT, could be coincidence, but it appears my amp turn-on-when-playing stopped working exactly when I did an OTA update to the latest version offered (3.758).
Moved to a different GPIO pin, no change.
Installed GPIO Control plug-in to try, not working either.
AmpSwitch lists as “inactive” regardless of being on or off, turns itself back on eventually even after I turn it off, and refuses to uninstall. GPIO Control installs and uninstalls just fine, toggles between “active” and “inactive” as expected.
Trying to avoid a full re-install from scratch, so thought I’d check first to see if anyone else has this issue.
Yes I did.
Please look at the opening post, what has been tested and which passed or failed (due to change in addressing GPIO).
Feel free to run test and report back. It will be very much appreciated.
Dear Beta Testers, I am trying to get Volumio running on one of these new Raspberry Pi 5 2 GB SBCs. If I understand correctly, the 3.758 image linked above is supposed to be bootable on this Pi, but it does not work for me. The Pi is fine, it runs multiple other images without issues, the SD cards is also fine (tested with h2testw). Tried flashing the image multiple times with multiple tools, but no dice. What am I missing here?
I repeated the previous steps again to have it documented properly, but this time it produced an SD card that boots fine. My conclusion is that the root cause of the issue was located between my chair and my monitor…
Now that it is working, let me add some feedback.
Hardware: Raspberry Pi 5 2 GB Model B Rev 1.0, HiFiBerry Digi2 Pro, FiiO K7
System Information
OS info
Version of Volumio: 3.758
Hostname: volumio
Kernel: 6.6.47-v8+
Governor: conservative
Uptime: 0 days, 0 Hrs, 12 Minutes, 27 Seconds
Network info
Interface: eth0
IP Address: 192.168.1.208
MAC Address: <removed>
Type: wired
Speed: 1000Mb/s
Audio info
Hw audio configured: HiFiBerry Digi+ Pro
Mixer type: None
Number of channels:
Supported sample rate:
Board info
Manufacturer:
Model: Raspberry Pi 5 Model B Rev 1.0 / /
Version: b04170 /
Firmware Version: 2024/09/10 14:40:30 version 5be4f304 (release) (embedded)
CPU info
Brand: BCM2712
Speed: 2.4 GHz
Family: unknown
Model: 1
Number of cores: 4
Physical cores: 4
Average load: 1%
Temperature: 52°C
Memory info
Memory: 2030532 Ko
Free: 1254140 Ko
Used: 776392 Ko
Software info
Mpd version: Music Player Daemon 0.23.15 (0.23.15)
Storage info
INTERNAL storage - Size: 26908Mo
Used: 383Mo
Available for storage: 25133Mo (93%)
Fusion DSP parametric equalizer- working
Spotify Connect - working
Spotify Browsing - working, after each reboot I need to click on Authorize again to re-enable browsing, but it does not ask for password
I was unable to use Hardware mixer on my HiFiBerry DAC2 Pro when I had the matching I2S DAC2 Pro selected. Switching I2S to DAC+ Pro allowed me to select hardware mixing.
Random crashes. Player stops working and comes back with the start up sound. But then requires reboot for the DLNA to be recognized. This happens at least once a session from an hour to six.
Yes this has been going on for over a year. I previously submitted an issue and it was believed it was being caused by the library. (over 3TB). I changed to using only as a DLNA endpoint but I still have the same issue.
