After the latest updates, I can no longer use Volumio, the first two starts is everything ok, but from the third onwards, it reports this error to me: Failed to open “alsa” (alsa); Failed to open ALSA device. Latest working version 3.661.
Do you have this problem only with Volumio, or did you also try other distribution like Raspbian.
I recall this behavior with one of my Hifiberry DAC2 which finally broke down.
I only have this problem with the latest version 3.703, with version 3.661 I have no problems currently but I’m using that. I don’t use other distribution, I love volumio
Jul 03 23:32:40 volumio systemd-udevd[355]: controlC1: Failed to open ATTR{/sys/devices/platform/soc/soc:sound/sound/card1/controlC1/../uevent} for writing: No such file or directory Jul 03 23:32:40 volumio kernel: snd-rpi-hifiberry-dacplushd soc:sound: ASoC: driver name too long 'HifiberryDacplusHD' -> 'HifiberryDacplu'
Above suggest incorrect dtoverlay or hw problem.
Since you mention that this is one of many Pi+DAC devices you have. Can you use the DAC from working setup to test?
I only have one hardware and I use two micro SD cards since the new versions don’t work. With the same hardware the 3.661 continues to work perfectly, while the subsequent versions do not work, I also tried the 3.735 but with the same problem. Thank you
I got " ERROR. Failed to open “ALSA” (Alsa)
Failed to open alsa device “volumio” no such device.
It works for years, after software updates it stop working.
Config:
Raspberry Pi 4B 4G and Hifibery DAC2 HD board. Hardware is OK, I installed HIfiBerryOS and this combination works. Use the latest Volumio version 3.703
Is there anyone with the same problems and solved it?
