Hello Thank you for your very valuable work, you are great - I love Volumio!
After the end of the Qobuz playlist, i.e. after a few hours, Volumio stops playing…
It looks like it’s playing music, but there’s no sound.
After pressing the pause button, you notice that Volumio no longer reacts or reacts very sluggishly.
At some point the interface actually shows Pause. Then on play - Volumio not responding. It looks like the 17th track won’t be played anymore. Although I’m not sure how many times the playlist was repeated and whether it was the 17th track both times… (I had activated queue replay) If I play the same playlist after a reboot and browse through the tracks, everything works very well good. Unfortunately I forgot to select a different playlist or source. I’ll catch up.
However, access to the interface (web and app (android) works normally.
I found the whole thing exactly the same with two different Qobuz playlists.
The reboot command works normally. After that everything works fine again.
Log:
http://logs.volumio.org/volumio/hgNat2c.html
RPI2
Allo HifiBerry DAC2 HD (My test system, otherwise I only use Allo BOSS2)
Hello Nirvana
Volume 3,395
Qobuz Hi-Res Masters: Indie-Folk Playlist (6:22)
Volumio Android App
Volumio web interface
Greetings
rost21A
I will update and see if the issues arise again . Now that it is fixed , I am curious .
