I updated nanopi images to Volumio 2.777 with kernel 5.4.44 and 5.4.44-rt27(with PREEMPT_PT patch).
HI, I’ve installed the latest NanoPi Neo Air image but I have no audio; I have the NanoHat PCM5102A and changed the Volumio setting to ‘External DAC’ is there anything else that I need to do?
Hi, I have NanoPi Neo with PCM5102 hat and I would like to know if there is any image based on the latest volumio for it.
Thanks.
I updated nanopi(neo, neo2, air, plus2, 2black) images to current Volumio version with kernel 5.10
For pcm5102 hat needed added/change dts overlays. I haven’t 5102 hat so I can’t made and check it.
Updated link to google-drive: shared - Google Drive
is it possible to have the NanoPi images with the latest certificate fix?
which version are you running now and from where was it downloaded?
It is one with myVolumio support?
There is a new one published in the NanoPi Neo3 thread.
I built one for the Neo2, with myVolumio functionality, but don’t know where to put it as there is no thread for it yet.
I got it from the google-drive link from nikkov
Can you share the link in this thread?
you did not answer my question yet
Which version did you have? Obviously without myVolumio.
I do not necessarily want to compete with the work @nikkov has done.
The “myVolumio” version is still using an older kernel, I will add the link in a new thread so things do not get mixed up.
OTA may not work, so you need to flash.
sorry I didn’t know the answer, I am flashing his latest image right now. I suppose without myvolumio.
I have a few spare NanoPi Neo2 and I want to use one for a tiny system to have Volumio in my car
ok, the Neo2 thread will be added sometime today when I’m near my desk.
Is there any reason to use the old kernel? I have already builded several versions on latest kernel versions and they all work great. And in the latest kernel I2S driver already supports up to 24 bit without any patches.
I updated nanopi(neo, neo2, air, plus2, 2black and cubietruck) images to current Volumio version + resolved certificate issue (marked as 2.916 version). link
Hi nikkov, thanks for your work on NEO. I’v a NanoPi Neo1.3, and the image not work, the image start, but no ssh and no volumio.local answer. Can you guide to connection?
thanks
It’s may be this issue:
Attention! By default image use i2s in slave mode and without external clock source will not work! You can change i2s mode to master by edit armbianEnv.txt, just replace
user_overlays=sun8i-h3-i2s0-slave
to
user_overlays=sun8i-h3-i2s0-master
Hi nikkov, thanks for your answer, ok for the i2s, but I loaded a image in my Nio 1.31 and nothing appair.
The Nio leds blink and the image start, but I can not comunicate in SSH or simply calling from browser volumio.local/ , can you conferm this problem?
thanks.
mabe can you geve me the right name of version for NEO 1.3 of using image? I using the Volumio2.916-2021-10-14-nanopineo.7z
mabe something is wrong?
thanks
and just another question is, can I access trough ssh?
thanks
You must change i2s settings even if you not planned using i2s dac, because with settings by default Volumio can’t start and you can’t access web-interface. Volumio try play start sound to i2s DAC, but just freeze because I2S clocks not exists.
Image Volumio2.916-2021-10-14-nanopineo.7z I tested on my own NanoPi Neo 1.31 and all works fine.
About SSH, please refer to Volumio docs: SSH - Volumio Documentation (How to enable SSH)
