Sta funzionando con factory s16 le
Sample rate 192 khz. Ho provato a riavviare più volte e ho sempre il suono.
someone tried dac usb with if2 purifier? i have khadas tone board and with usb and very noisy with active plugin.
sorry for all requests. I used the working plugin these days. last night I wanted to do some measures to create filters. just start the tool and give the play left or right restart the player and stop playing. at that point I have to uninstall and re-install brutefir.what can it be?
What is the version of the plugin you are using?
Last
I have to check something…
ok.dimmi me also the dac you use with the plugin. so I buy it too and there is no need for me to write you all the problems problemi
I use a Allo boss player ( Allo boss DAC and rpi3).
And a iquadio DAC plus with a pri2.
And a usb fxaudio FDA f802 with pine64.
I buy another dac. I can’t use brutefir with any of my dacs. i have khadas tone board and m audio fast track.i2s i only transport type iqaudio pi digi.e does not work with it either. I’d like to listen to audiophonics 9038. but if I talk about it a little I’m afraid it will cause problems. I think I will buy the boss v1.2
I realized something. If I install volume on the micro sd and download it in plugin everything works. If I start touching the options and it stops playing I have to do it all over again. as if the micro sd were corrupted.
it would be interesting to know where to act to avoid rewriting volumes. ie in which folder to delete the data of the last connected dac. or better still via shh.
the tools are ok now. I have seen that when brutefir stops working the config folder and the only folder that changes the date. ?
config is corrupt. I have re-installed volume and copied the config folder on the pc. Can the contents of config be restored via ssh?
Honestly, I don’t understand what you mean when you write config is corrupted. Do you mean volumio is dead, or the plugin? Or just no sound? Can you clarify?
when I change the settings the plugin stops working. if I explore the micro sd I see the config folder. Corrupted. I wanted to know if I could restore it without re-installing volume
I made the measurements with rew and created the filters with rephase. but I can’t insert them in volume. I’m looking on the forum but I can’t find anything. The wiki says to put them in the shared volumio folder but I don’t see how.
From your files explorer in Windows, type as URL “file://ipadressofvolumio”
And put your files in /brutefirfilters.
Then go in plugin settings and select your files. Change if required the filter format.
it tells me file not found
it tells me file not found. with volume connected to the network. maybe I have to put the micro sd in the pc?
Try this : techrepublic.com/article/ho … indows-10/
