is there a way to uninstall via ssh? i installed brutefir 2 and I do not get rid of it anymore
A bug (fix soon) in volumio prevents plugin to be removed.
Vis ssh, you can do the following :
rm -Rf /data/plugins/audio_interface/brutefir
and reboot your system.
But please, as it is written in github, do not use brutefir2 as it is unmaintainedâŚ
FYI, BruteFIR is working very well with my new Allo Katana stack pool as n rPi. Thanks again balbuze for all your efforts!
Sent from my SM-N950W using Tapatalk
I finally have a configuration that works and that from very little tic toc.with dac usb khadas tone board.Iâm happy. now I have to test it for many hours
try the last hour.raspberry with iq audio card plus digi + .enter in khadas tone board.
resempling at 192k.are perfect clean and brutefir does not create any disturbance.I am sorry for the native dsd but this is my ideal configuration until the purchase of the dac katana.
never again dac usb on raspberry âŚ
is it possible to install eq 30 bands on brutefir 3?
for now I donât want to use the filter system and I would like more intervention range for calibration in the car.
help me please balbuze.I installed the system in the car and updated volume. brutefir does not work anymore. after several attempts to turn on and off the plugin the sound finally arrives. but as soon as I reboot the system, the sound no longer comes. with the previous version of volume it seemed to work well. what do you suggest me to do?
Hi!
If it was working with previous version, I have a small idea why itâs not working anymore⌠Let me have a lookâŚ
please try : https://github.com/balbuze/volumio-plugins/raw/master/plugins/audio_interface/brutefir3/brutefir.zip
how do you install it in volume?
ok ok .i understand
I thought I needed to reinstall it. Instead, this morning the key is around and here is the music. I donât know why, but itâs ok. Thanks for everything you do. I am now ready to create the filters. I have already seen the guide. I have not understood how to insert them in the shared volumio folder. But I try.
Iâm sorry to say but it doesnât work anymore. I updated it but nothing. It doesnât work. I left all the default settings. I donât understand
it doesnât work. I donât know what to do anymore. I spent time and money making a car system without dsp.puntavo on brutefir. at least tell me how do you go to previous versions of volume?
uninstall the plugin. Reconfigure volumio, reboot and test if everything is ok. Then install the plugin, enable it. Wait 20seconds and play a track.
And donât forget itâs free, open source and with no warranty⌠So donât be rude
I can guarantee you that I am not rude. I am only disappointed. but unfortunately the translator translates me in his own way. He makes me look bad. I will never cease to thank you
so I no longer have to update volume?
then summarizing. I have reset volume re-installed brutefir.la configuration I leave by default. on reproduction I have iq audio pi digi +. when I turn on the plugin it becomes iq audio through brutefir. loopback I donât know what it is. I donât know if Iâm wrong or if the i2s digital card is not good. I go digital and go to the khadad tone board. via usb it works but it makes too many pop clik. if I have to buy a real dac i2s itâs okay. but I donât understand why sometimes it works and others donât.
When you enable the plugin, Donât change anything in volumio playback settings! Donât change i2s status, volume mixer setting etc.
Just make your system working without the plugin, then enable it. Just change value in plugin settings.
Let me know.
