using Vers. 3.173 at the moment with an iQAudio DAC+ as headphone amp.
I set the max. Volume setting of the hardware mixer to 50%, as my headphones are really easy to drive.
This setting is respected and the Volume slider always drops back to 50% when I try to go higher. But the volume increment setting is always at 5%, it does ignore the “one click volume step” setting I did. So I can only change the volume I am listening to in very big steps. And it is very sensitive to set (small movement results in big change).
I would love if the volume slider would be rescaled between zero volume and the max. Volume setting. And of course the volume step setting should be respected as well.
Yes, that´s what I did. Has no effect, always stays at 5% steps. This setting does not work and should be fixed. And additional the slider should be rescaled to only show the range between zero and the “max volume level” setting, so it would be finer to adjust.
Just tried it, that setting does not change the behaviour at all on my system. It is always 5% steps, no matter if the setting is at 1 or 20…it is always 5% steps based on the full 0 - 100% scale.
A setting of 1 of 2 would also make no sense imho.
weird. I checked on two system PRIMO and RPI4 and it just work as expected with step 1.
Can you give log after reboot, set to 1 and change volume using one click please?
One more think I just discovered: When I switch to the “now playing” interface I can change the volume slider in 1% steps (but still independend from the “One Click Volume Steps” setting - it has no effect at all). And of course the “now playing” interface is only available in the webinterface, not in the app (which I use mostly from my tablet).
Rescaling of the complete slider would be great here as well of course…
