See, i only have Volumio on my Raspberry Pi 4.
One, can i install Python on the Raspberry Pi 4
as are these the right steps on installing it.
sudo apt-get update
sudo apt-get install -y build-essential tk-dev libncurses5-dev libncursesw5-dev libreadline6-dev libdb5.3-dev libgdbm-dev libsqlite3-dev libssl-dev libbz2-dev libexpat1-dev liblzma-dev zlib1g-dev libffi-dev tar wget vim
wget https://www.python.org/ftp/python/3.8.0/Python-3.8.0.tgz
sudo tar zxf Python-3.8.0.tgz
cd Python-3.8.0
sudo ./configure --enable-optimizations
sudo make -j 4
sudo make altinstall
python3.8 -V
echo "alias python=/usr/local/bin/python3.8" >> ~/.bashrc
source ~/.bashrc
Just to clarify
- It shouldn’t matter what pi you are on, on Volumio at least.
- Are you looking specifically for python 3? Python 2 is already shipped with Volumio, just try
python --version to confirm.
If you can survive with Python 3.4, you should be able to directly install it with apt install python3
The steps you have outlined above builds python from source, and symlinks the resulting binary to python3.8
PS: I wouldn’t recommend blindly copy pasting commands from the internet into your terminal, take some time to read up what each command does…
How do i install lirc to install the IR receiver.
I get that the power from the ir receiver VS1883B connects to the 3v3 pin on the GPIO pin and the ground to the ground pin but what about the S out on the IR receiver what GPIO that goes to. On that i hear GPIO18 GPIO RX or TX
Not sure I follow - your post (and the code you pasted in) is about using Python on the pi4, but you seem to be talking about a Infrared receiver now?
Please try the IR receiver plug-in thread for support on that…
