Use of HDMI Touch screen with Primo 2
just bought the volumio Primo2. I would like to add a touch display on the hdmi port of the Primo2. Does that work with this raspberry setup, or what is the easiest way?
thanks for any hint
Hey @hpz,
Your question is unrelated to the MIPI screen type. Moved to a separate topic.
Perhaps @DED can chip here in or take via different communication channel.
I point you to this thread, here you can find some plug&play compatible touch display models
Best,
Davide
VOLUMIO TECH SUPPORT
