What size do you advice me for Volumio on Usb pendrive?
Does Volumio work on usb drive, with no need to installing?
Thank you
Thank you
Thank you
in case you only want to boot from it, then 8Gb will already do.
I would advice 16-32Gb to give you some slack.
32 gb
Please post in the x86 thread, I only read there regularly for PC related issues.
Btw. was this an answer or a question?
My pendrive is a sandisk 32gb
perfect
Where is x86 thread?
Just take your time to browse the forum instead of me just giving you a step-by-step guidance. The forum also has a search function, what about looking for “x86”?
Yes I started Volumio 3 on usb pendrive for windows pc.
But I can’t see my dac Upnp.
And the answers are not available.
Bad support service.
Sorry,
Need to reply.
You’ve dropped a bombshell of easy questions which are easy to find when you use the search function but still many people spend their free time to answer them for you.
And now a very specific question on an uPnP DAC takes longer to be answered as this is not frequently used and you claim bad support.
Please hold back on these kind of remarks.
Lot of dac are upnp and lot of player, also free, see the upnp device.
Foobar, Daphile, Audirvana, Roon, and so on.
For Volumio is a very difficult question, isn’t it?
never use it but this is my first attempt via an android smartphone. he sees him.
This application.
thanks but I didn’t understand. do you use Volumio and using the Volumio interface were you able to see your upnp dac? I know Bubbleupnp but I don’t understand how it relates to Volumio.
I hope you’ll help me
Software volumio and i2s dac attached on volumio.
Stream from android smartphone to volumio software.
and the sound is played via volumio with an i2s dac attached.
Volumio interface - volumio android app
But my dac is not attached with pc volumio.
It is under net lan and it is a Upnp device
Audio device is only two options: Analog and HDMI
No many more, under i2s dac, via a Raspberry Pi.
I’ll don’t use PC.
which equipment is that…brand and type number? otherwise it just becomes a bit of a guess.
With all other player, daphile roon audirvana, is possible setting audio device upnp
you say daphile works, daphile is lms based maybe you should install lms plugin
