Yes I did it.
My Dac is an Atoll MS120 without usb port. Only LAN
but have you gone through the setup of lms plugin.
By the way, the Atoll MS120 has plenty of inputs and outputs.
you could just use a Stereo plug from your PC to your Atoll.
Rca? And DAC?
LMS plugin setting what?
sorry but i’ll stop. go do your homework first
If i use rca input of my Atoll, the dac is bypassed. And i want to use the dac of MS120.
The LMS plugin is activated and i don’t know if there is a setting menu.
