Update Android app doesn´t work correct
Good morning,
My android app on my smartphone shows a black screen after I have choosen the starting screen. This one works as usual, but when I had choosen the player it switches to a black screen on the following page. It seems to work as it should as you can play music or repeat a song or switch to the following song, but I see on the screen remain black.
Does anyone has got a solution for this issue?
Thank you Olaf
I will try and delete the app and reinstall and give information. It is version 1.10.0.
Volumio 3 Issues?
