DISCLAIMER: Radxa Zero images are unofficial and released “as-it-is”.
No official support will be provided for this device, but help from other community members is more than welcome.
Updates will be released from time-to-time, without a regular schedule. They can be applied with OTA update or by flashing the new image on the SD-card.
Please use this topic to discuss or report Radxa Zero bugs and other issues.
Versions, bug fixes and new features
See Versions, bug fixes and new features
Radxa Zero (Amlogic S905Y2)
Radxa Zero is an ultra thin SBC in small form factor with powerful performance based on Amlogic S905Y2. It can run Android and selected Linux distributions like Volumio.
Radxa Zero features a quad core 64-bit ARM processor, up to 4GB 32bit LPDDR4 memory, HDMI output at 4K@60, WiFi and BT connectivity, USB 3.0, and 40-pin GPIO header. Additionally, the power port can also be used for USB 2.0 OTG to connect more peripheral.
Radxa Zero comes in multiple configurations to suit your need. Please check available models for detail.
The recommendation is to use a 1GB board version as a minimum.
For using SPDIF or I2S, select one with a soldered 40-pin connector (unless you can solder the necessary pins yourself).
Audio options
HDMI, SPDIF and USB.
SPDIF is found on pin 19 with pin 20 used for GND.
(Pinout for I2S will be added after it has been made available).
For further information, please refer to the Radxa Wiki
