Unable to access plugins myvolumio says I'm not logged
Hi.
For a week now I’m not seeing Qobuz available to me.
When I try to access plugins I keep getting a message saying that I’m not logged. But I’m logged.
I’ve already tried to log out manually then log in to no avail.
Can anyone help me here?
PS: I’m running the latest version of Volumio3 on a Rpi 3B+
Please check your date. If the dat is to far in the past, the login will fail.
Date Time issues rPi4 - #57 by Wheaten.
My date is set to 12th August
I have no idea how this happened.
I will follow your tutorial in order to try to fix this.
This happened when I executed the last part:
volumio@volumio:~$ sudo chmod 644 /lib/systemd/system/setdatetime.service && sudo systemctl daemon-reload && sudo systemctl enable setdatetime.service && sudo systemctl start setdatetime.service
Failed to enable unit: File setdatetime.service: Bad messa
Any ideas?
There has been a batch of rPi4, which has this problem for no understandable reason. I have one giving me this problem regular, so added the script to solve it.
What is the output of:
sudo cat /lib/systemd/system/setdatetime.service
volumio@volumio:~$ sudo cat /lib/systemd/system/setdatetime.service
[Unit] Description=Set local time using time server
[Service] Type=oneshot ExecStart=/bin/bash -c “sleep
30; /usr/bin/sudo /bin/date -s "$(/usr/bin/curl -s
–head http://google.com | grep ^Date: | sed
‘s/Date: //g’)"” [Install]
WantedBy=multi-user.target
For the record. I’m running Volumio on a Rpi 3B+ and this issue was introduced after the latest update. It was the only thing new I did I can think of.
No, 12th Aug is the date of the image. You rPi3 has not synched the time yet.
Did you follow the instruction and use nano, it seems you’ve pasted everything with windows line feeds.
it should look like this:
I’ll redo it.
The issue is I’m without my laptop today. I’m doing this over Android.
Is there a way I can set this date manually over a simple command line and later this weekend fix this properly when my laptop arrives?
yes simply run:
/bin/bash -c "sleep 1; /usr/bin/sudo /bin/date -s \"$(/usr/bin/curl -s --head http://google.com | grep ^Date: | sed 's/Date: //g')\""
Thank you
It worked.
Qobuz is back. And I’m about to access plugins again.
I’m getting an error though when I try to update the latest YouTube Cast Receiver:
Downloading plugin at https://plugins.volumio.workers.dev/pluginsv2/downloadLatestStable/ytcr/volumio/buster/armhf
END DOWNLOAD: https://plugins.volumio.workers.dev/pluginsv2/downloadLatestStable/ytcr/volumio/buster/armhf
Creating install location
An error occurred while updating the plugin TypeError [ERR_INVALID_ARG_TYPE]: The “listener” argument must be of type function. Received undefined
Do you think it has something to do with this time issue?
Not related to the date.
That one you can report in the plugin topic if it keeps happening.
I’ll observe it.
Thanks a lot
I had the same issue. Installed cron and mentioned script is running right after startup with little modification to do not ask for password
