Touch Display Plugin Installation Error
Volumio 3 Issues?
@dvoltz Sir I have installed the latest version of Volumio on my Allo USB Signature Player which comes with a Raspberry Pi. The concern is I am not able to instal the Touch Display Plugin.
I tried 3.5.1(stable) but my downaloding gets stuck at 70%. I have shared below the status as and when I run the installation. I evern tried 3.1.1 but same issue. Kindly help…
Downloading plugin at https://plugins.volumio.workers.dev/pluginsv2/downloadLatestStable/touch_display/volumio/buster/armhf
END DOWNLOAD: https://plugins.volumio.workers.dev/pluginsv2/downloadLatestStable/touch_display/volumio/buster/armhf
Creating install location
Unpacking plugin
Checking for duplicate plugin
Copying plugin to location
Completing “UIConfig.json”
Installing fake packages for kernel, bootloader and pi lib
Selecting previously unselected package libraspberrypi0.
(Reading database … 34540 files and directories currently installed.)
Preparing to unpack …/libraspberrypi0_0.0.1_all.deb …
Unpacking libraspberrypi0 (0.0.1) …
Setting up libraspberrypi0 (0.0.1) …
Selecting previously unselected package raspberrypi-bootloader.
(Reading database … 34544 files and directories currently installed.)
Preparing to unpack …/raspberrypi-bootloader_0.0.1_all.deb …
Unpacking raspberrypi-bootloader (0.0.1) …
Setting up raspberrypi-bootloader (0.0.1) …
Selecting previously unselected package raspberrypi-kernel.
(Reading database … 34548 files and directories currently installed.)
Preparing to unpack …/raspberrypi-kernel_0.0.1_all.deb …
Unpacking raspberrypi-kernel (0.0.1) …
Setting up raspberrypi-kernel (0.0.1) …
Putting on hold packages for kernel, bootloader and pi lib
libraspberrypi0 set on hold.
raspberrypi-bootloader set on hold.
raspberrypi-kernel set on hold.
Installing Chromium dependencies
Hit:1 [Index of /debian](http://archive.raspberrypi.org/debian) buster InRelease
Hit:2 [Index of /raspbian](http://raspbian.raspberrypi.org/raspbian) buster InRelease
Hit:3 [Index of /node_14.x/](https://deb.nodesource.com/node_14.x) buster InRelease
Reading package lists…
Building dependency tree…
Reading state information…
0 upgraded, 0 newly installed, 0 to remove and 50 not upgraded.
Installing graphical environment
The following additional packages will be installed:
keyboard-configuration libegl-mesa0 libegl1 libegl1-mesa libepoxy0 libevdev2
libfontenc1 libgbm1 libgudev-1.0-0 libinput-bin libinput10 libmtdev1
libpciaccess0 libunwind8 libutempter0 libwacom-bin libwacom-common libwacom2
libwayland-server0 libxaw7 libxcomposite1 libxfont2 libxft2 libxkbfile1
libxmu6 libxmuu1 libxpm4 libxt6 libxxf86dga1 x11-utils x11-xkb-utils xauth
xbitmaps xfonts-base xfonts-encodings xfonts-utils xserver-common
xserver-xorg xserver-xorg-core xserver-xorg-input-all
xserver-xorg-input-libinput xserver-xorg-input-wacom xserver-xorg-legacy
xserver-xorg-video-all xserver-xorg-video-amdgpu xserver-xorg-video-ati
xserver-xorg-video-fbdev xserver-xorg-video-nouveau
xserver-xorg-video-radeon xserver-xorg-video-vesa xterm
Suggested packages:
pciutils mesa-utils xfonts-100dpi | xfonts-75dpi xfonts-scalable xinput
firmware-amd-graphics xserver-xorg-video-r128 xserver-xorg-video-mach64
xfonts-cyrillic
The following NEW packages will be installed:
xbitmaps xfonts-base xfonts-encodings xfonts-utils xinit xserver-common
0 upgraded, 52 newly installed, 0 to remove and 50 not upgraded.
Need to get 11.0 MB/19.0 MB of archives.
After this operation, 32.1 MB of additional disk space will be used.
Err:1 [Index of /raspbian/raspbian](http://raspbian.mirror.net.in/raspbian/raspbian) buster/main armhf keyboard-configuration all 1.193~deb10u1
Connection failed [IP: 103.195.68.3 80]
Err:2 [Index of /raspbian/raspbian](http://raspbian.mirror.net.in/raspbian/raspbian) buster/main armhf libxxf86dga1 armhf 2:1.1.4-1
Err:3 [Index of /raspbian/raspbian](http://raspbian.mirror.net.in/raspbian/raspbian) buster/main armhf libwayland-server0 armhf 1.16.0-1
Err:4 [Index of /raspbian/raspbian](http://raspbian.mirror.net.in/raspbian/raspbian) buster/main armhf libepoxy0 armhf 1.5.3-0.1
Err:5 [Index of /raspbian/raspbian](http://raspbian.mirror.net.in/raspbian/raspbian) buster/main armhf libevdev2 armhf 1.6.0+dfsg-1
Err:6 [Index of /raspbian/raspbian](http://raspbian.mirror.net.in/raspbian/raspbian) buster/main armhf libfontenc1 armhf 1:1.1.3-1
Err:7 [Index of /raspbian/raspbian](http://raspbian.mirror.net.in/raspbian/raspbian) buster/main armhf libgudev-1.0-0 armhf 232-2+rpi1
Err:8 [Index of /raspbian/raspbian](http://raspbian.mirror.net.in/raspbian/raspbian) buster/main armhf libwacom-common all 0.32-1
Err:9 [Index of /raspbian/raspbian](http://raspbian.mirror.net.in/raspbian/raspbian) buster/main armhf libwacom2 armhf 0.32-1
Err:10 [Index of /raspbian/raspbian](http://raspbian.mirror.net.in/raspbian/raspbian) buster/main armhf libinput-bin armhf 1.12.6-2+deb10u1
Err:11 [Index of /raspbian/raspbian](http://raspbian.mirror.net.in/raspbian/raspbian) buster/main armhf libmtdev1 armhf 1.1.5-1+b2
Err:12 [Index of /raspbian/raspbian](http://raspbian.mirror.net.in/raspbian/raspbian) buster/main armhf libinput10 armhf 1.12.6-2+deb10u1
Err:13 [Index of /raspbian/raspbian](http://raspbian.mirror.net.in/raspbian/raspbian) buster/main armhf libpciaccess0 armhf 0.14-1
Err:14 [Index of /raspbian/raspbian](http://raspbian.mirror.net.in/raspbian/raspbian) buster/main armhf libunwind8 armhf 1.2.1-10~deb10u1
Err:15 [Index of /raspbian/raspbian](http://raspbian.mirror.net.in/raspbian/raspbian) buster/main armhf libutempter0 armhf 1.1.6-3
Err:16 [Index of /raspbian/raspbian](http://raspbian.mirror.net.in/raspbian/raspbian) buster/main armhf libwacom-bin armhf 0.32-1
Err:17 [Index of /raspbian/raspbian](http://raspbian.mirror.net.in/raspbian/raspbian) buster/main armhf libxt6 armhf 1:1.1.5-1+b3
Err:18 [Index of /raspbian/raspbian](http://raspbian.mirror.net.in/raspbian/raspbian) buster/main armhf libxmu6 armhf 2:1.1.2-2+b3
Err:19 [Index of /raspbian/raspbian](http://raspbian.mirror.net.in/raspbian/raspbian) buster/main armhf libxpm4 armhf 1:3.5.12-1
Err:20 [Index of /raspbian/raspbian](http://raspbian.mirror.net.in/raspbian/raspbian) buster/main armhf libxaw7 armhf 2:1.0.13-1+b2
Err:21 [Index of /raspbian/raspbian](http://raspbian.mirror.net.in/raspbian/raspbian) buster/main armhf libxcomposite1 armhf 1:0.4.4-2
Err:22 [Index of /raspbian/raspbian](http://raspbian.mirror.net.in/raspbian/raspbian) buster/main armhf libxfont2 armhf 1:2.0.3-1
Err:23 [Index of /raspbian/raspbian](http://raspbian.mirror.net.in/raspbian/raspbian) buster/main armhf libxft2 armhf 2.3.2-2
Err:24 [Index of /raspbian/raspbian](http://raspbian.mirror.net.in/raspbian/raspbian) buster/main armhf libxkbfile1 armhf 1:1.0.9-2
Err:25 [Index of /raspbian/raspbian](http://raspbian.mirror.net.in/raspbian/raspbian) buster/main armhf libxmuu1 armhf 2:1.1.2-2+b3
Err:26 [Index of /raspbian/raspbian](http://raspbian.mirror.net.in/raspbian/raspbian) buster/main armhf x11-utils armhf 7.7+4
Err:27 [Index of /raspbian/raspbian](http://raspbian.mirror.net.in/raspbian/raspbian) buster/main armhf x11-xkb-utils armhf 7.7+4
Err:28 [Index of /raspbian/raspbian](http://raspbian.mirror.net.in/raspbian/raspbian) buster/main armhf xauth armhf 1:1.0.10-1
Err:29 [Index of /raspbian/raspbian](http://raspbian.mirror.net.in/raspbian/raspbian) buster/main armhf xbitmaps all 1.1.1-2
Err:30 [Index of /raspbian/raspbian](http://raspbian.mirror.net.in/raspbian/raspbian) buster/main armhf xfonts-encodings all 1:1.0.4-2
Err:31 [Index of /raspbian/raspbian](http://raspbian.mirror.net.in/raspbian/raspbian) buster/main armhf xfonts-utils armhf 1:7.7+6
Err:32 [Index of /raspbian/raspbian](http://raspbian.mirror.net.in/raspbian/raspbian) buster/main armhf xfonts-base all 1:1.0.5
Err:33 [Index of /raspbian/raspbian](http://raspbian.mirror.net.in/raspbian/raspbian) buster/main armhf xinit armhf 1.4.0-1
Err:34 [Index of /raspbian/raspbian](http://raspbian.mirror.net.in/raspbian/raspbian) buster/main armhf xserver-xorg-video-amdgpu armhf 18.1.99+git20190207-1
Err:35 [Index of /raspbian/raspbian](http://raspbian.mirror.net.in/raspbian/raspbian) buster/main armhf xserver-xorg-video-radeon armhf 1:19.0.1-1
Err:36 [Index of /raspbian/raspbian](http://raspbian.mirror.net.in/raspbian/raspbian) buster/main armhf xserver-xorg-video-ati armhf 1:19.0.1-1
Err:37 [Index of /raspbian/raspbian](http://raspbian.mirror.net.in/raspbian/raspbian) buster/main armhf xserver-xorg-video-fbdev armhf 1:0.5.0-1+b2
Err:38 [Index of /raspbian/raspbian](http://raspbian.mirror.net.in/raspbian/raspbian) buster/main armhf xserver-xorg-video-nouveau armhf 1:1.0.16-1
Err:39 [Index of /raspbian/raspbian](http://raspbian.mirror.net.in/raspbian/raspbian) buster/main armhf xserver-xorg-video-vesa armhf 1:2.4.0-1+b1
i don’t think you will find @gvolt there but did you enable the plugin?
ps gvolt i didn’t know that you had those releases gniffle…
The problem you have is network related IMHO. During the plugin’s installation process a bunch of additional software has to be downloaded and installed. But there seems to be a problem connecting the repository server from which these software packages would be downloaded.
I suggest to restart Volumio and try again later to install the plugin, hoping the repository will be reachable then. If that does not work out you may change to another repository mirror as described here.
P.S. I recommend to use plugin version 3.3.5. Unlike 3.3.1 this version detects download errors and cancels the installation of the plugin, avoiding the impression that the plugin has been installed successfully even if download errors did occur.
Thanks @gvolt you were 100% correct. Changing the repository mirror worked out and finally now my Touch Display got installed and working perfectly.
i am unable to even after changing mirror,…and being new user unable to post my entire err message i got…
i changed the repository mirror as advised by gvolt but still am unable to install a touch display plugin…please guide how you got it done?/?
