Stop the Touch Display plugin, execute
sudo curl -L https://raw.githubusercontent.com/goodtft/LCD-show/master/usr/99-fbturbo.conf -o /usr/share/X11/xorg.conf.d/99-fbturbo.conf
and start the Touch Display plugin.
It doesn´t work
. But I´m going to try with a fresh volumio instalation in the next few days when my work allow me
thank you so much!!
Please post the output of
cat /var/log/Xorg.0.log
again.
What I did to solve this issue with my RPi5 is:
Section âOutputClassâ
Identifier âvc4â
MatchDriver âvc4â
Driver âmodesettingâ
Option âPrimaryGPUâ âtrueâ
EndSection
After SSH to Volumio, type this command in the Terminal (Mac). âsudo chmod -R 777 /etc/X11/xorg.conf.dâ
Copy the â99-vc4.confâ file into â/ect/X11/xorg.conf.dâ via FileZilla/WinSCH.
Reboot
I got it to work every time I install a fresh Volumio into my RPi5. Hope this helps.
Andy
Hello, sorry, it was a little hard week, I have a 1 year old doughter and my moments for this raspberry pi project scarce ![]()
I have begun in a fresh instalation of volumio 3.601 and do this https://community.volumio.com/t/ili9341-2-8-tft/52483/5?u=mangas, and this https://community.volumio.com/t/volumio-with-3-5-tft-touch-screen-gpio-rpi-3b/11265/341?u=mangas. Then this https://community.volumio.com/t/issues-with-rpi5-waveshare-hdmi-display/63934/128 and this https://community.volumio.com/t/touch-display-not-working-in-v-3-601/65069/21?u=mangas. But no way, it doesn´t work.
This is the output of âcat /var/log/Xorg.0.logâ
volumio@volumio:~$ cat /var/log/Xorg.0.log
[ 189.278]
X.Org X Server 1.20.4
[ 189.278] Build Operating System: Linux 5.4.0-109-generic armv8l Raspbian
[ 189.278] Current Operating System: Linux volumio 6.1.70-v8+ #1712 SMP PREEMPT Tue Jan 2 18:31:53 GMT 2024 aarch64
[ 189.278] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 smsc95xx.macaddr=D8:3A:DD:ED:15:87 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000 splash plymouth.ignore-serial-consoles dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0xF dwc_otg.nak_holdoff=1 quiet console=ttyAMA10,115200 console=tty1 imgpart=/dev/mmcblk0p2 imgfile=/volumio_current.sqsh rootwait bootdelay=5 elevator=noop logo.nologo vt.global_cursor_default=0 net.ifnames=0 snd-bcm2835.enable_compat_alsa= snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 loglevel=0
[ 189.278] Build Date: 04 April 2023 07:50:56AM
[ 189.278] xorg-server 2:1.20.4-1+rpt4+deb10u9 (https://www.debian.org/support)
[ 189.278] Current version of pixman: 0.36.0
[ 189.278] Before reporting problems, check http://wiki.x.org
[ 189.278] Markers: (--) probed, (**) from config file, (==) default setting,
[ 189.278] (==) Log file: "/var/log/Xorg.0.log", Time: Sun Feb 11 18:48:40 2024
[ 189.278] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 189.278] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 189.278] (==) No Layout section. Using the first Screen section.
[ 189.278] (==) No screen section available. Using defaults.
[ 189.278] (**) |-->Screen "Default Screen Section" (0)
[ 189.278] (**) | |-->Monitor "<default monitor>"
[ 189.282] (==) No device specified for screen "Default Screen Section".
Using the first device section listed.
[ 189.282] (**) | |-->Device "Allwinner A10/A13/A20 FBDEV"
[ 189.282] (==) No monitor specified for screen "Default Screen Section".
[ 189.282] (==) Automatically adding devices
[ 189.282] (==) Automatically enabling devices
[ 189.282] (==) Automatically adding GPU devices
[ 189.284] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 189.284] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 189.284] Entry deleted from font path.
[ 189.285] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[ 189.285] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 189.285] (II) The server relies on udev to provide the list of input devices.
[ 189.285] (II) Loader magic: 0x1fdf80
[ 189.285] (II) Module ABI versions:
[ 189.285] X.Org ANSI C Emulation: 0.4
[ 189.285] X.Org Video Driver: 24.0
[ 189.285] X.Org XInput driver : 24.1
[ 189.285] X.Org Server Extension : 10.0
[ 189.285] (--) using VT number 2
[ 189.285] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 189.286] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 189.286] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 189.286] (**) OutputClass "vc4" setting /dev/dri/card1 as PrimaryGPU
[ 189.287] (II) LoadModule: "glx"
[ 189.287] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 189.299] (II) Module glx: vendor="X.Org Foundation"
[ 189.299] compiled for 1.20.4, module version = 1.0.0
[ 189.299] ABI class: X.Org Server Extension, version 10.0
[ 189.299] (II) LoadModule: "fbturbo"
[ 189.299] (II) Loading /usr/lib/xorg/modules/drivers/fbturbo_drv.so
[ 189.301] (II) Module fbturbo: vendor="X.Org Foundation"
[ 189.301] compiled for 1.20.3, module version = 0.5.1
[ 189.301] Module class: X.Org Video Driver
[ 189.301] ABI class: X.Org Video Driver, version 24.0
[ 189.301] (II) FBTURBO: driver for framebuffer: fbturbo
[ 189.301] (WW) Falling back to old probe method for fbturbo
[ 189.301] (II) Loading sub module "fbdevhw"
[ 189.301] (II) LoadModule: "fbdevhw"
[ 189.301] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 189.302] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 189.302] compiled for 1.20.4, module version = 0.0.2
[ 189.302] ABI class: X.Org Video Driver, version 24.0
[ 189.302] (EE) open /dev/fb1: No such file or directory
[ 189.302] (WW) Falling back to old probe method for fbturbo
[ 189.302] (II) Loading sub module "fbdevhw"
[ 189.302] (II) LoadModule: "fbdevhw"
[ 189.302] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 189.302] (EE) No devices detected.
[ 189.302] (EE)
Fatal server error:
[ 189.302] (EE) no screens found(EE)
[ 189.302] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 189.302] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 189.302] (EE)
[ 189.302] (EE) Server terminated with error (1). Closing log file.
thank you
thank you but it doesn´t work for me ![]()
sudo apt-get -y install xserver-xorg-video-fbturbo
and start the plugin.
A post was merged into an existing topic: [PLUGIN] Touch Display
