Hello Volumio-Team
I noticed the same thing too. The bug doesn’t seem to have been fixed yet.
The time bar display is often incorrect and shows an incorrect progress of the current track. The error occurs whenever the app is in the background for a period of time or the device is unlocked from the lock screen.
This in the app but also in the web GUI. If you have both open, they both show different progress…
It’s often really awkward when you want to fast forward or rewind and look for a specific spot.
The time is correct when a new track starts.
The display should often be adjusted correctly.
It would be nice if this can be fixed.
I use Qobuz
Volumio 3.396
I don’t use Spottify myself, but my colleague does. With him, the error occurs even more. (MiniDSP SHD)
