Here’s a log including the switch from Volume Control “none” to “software.” I couldn’t find hw_params.
Starting Live Log…
process exited with code null[Vollibrespot] : Failed to register IPv6 receiver: Os { code: 19, kind: Other, message: “No such device” }
info: VolumeController::SetAlsaVolume100
info: Killing previous LiveLog session
info: Live Log process terminated: null
info: CALLMETHOD: audio_interface alsa_controller saveVolumeOptions [object Object]
info: CoreCommandRouter::executeOnPlugin: alsa_controller , saveVolumeOptions
info: Restoring Previous Volume level: 100 false true
info: Enable softmixer device for audio device number 2
info: CoreCommandRouter::volumioStop
info: CoreStateMachine::stop
UNSET VOLATILE
xcb_connection_has_error() returned true
info: CoreCommandRouter::volumioUpdateVolumeSettings
info: Updating Volume Controller Parameters: Device: 2 Name: snd_rpi_rpi_dac Mixer: Max Vol: 100 Vol Curve; logarithmic Vol Steps: 5
info: Output device has changed, restarting MPD
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/chmod 777 /etc/mpd.conf
info: Output device has changed, restarting Shairport Sync
info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl restart mpd.service
Stopping Music Player Daemon…
info: Could not detect Primo: Error: Command failed: aplay -l | grep es90x8q2m-dac-dai-0
[SpotifyConnect] Creating VLS config file
info: Volume configurations have been set
[SpotifyConnect] <> or Mixer found, using softvol
info: Updating Volume Controller Parameters: Device: 2 Name: softvolume Mixer: Max Vol: 100 Vol Curve; logarithmic Vol Steps: 5
Starting Music Player Daemon…
------------------------------------ BT MESSAGE: BT STATUS: running
BT PLUGIN MESSAGE: Playing: false
BT PLUGIN MESSAGE: VOLATILE: undefined
BT PLUGIN MESSAGE: STATE:undefined
------------------------------------ BT MESSAGE: BT STATUS: waiting
info: MPD Permissions set
info: Asound.conf file written
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/mv /home/volumio/.asoundrc /etc/asound.conf
Started Music Player Daemon.
Playing WAVE ‘/volumio/app/silence.wav’ : Signed 16 bit Little Endian, Rate 44100 Hz, Stereo
info: Updating Volume Controller Parameters: Device: 2 Name: softvolume Mixer: SoftMaster Max Vol: 100 Vol Curve; logarithmic Vol Steps: 5
info: CoreCommandRouter::executeOnPlugin: system , getConfigParam
info: CoreCommandRouter::executeOnPlugin: i2s_dacs , getI2sOptions
info: CoreCommandRouter::executeOnPlugin: i2s_dacs , getI2sStatus
info: Getting Alsa Cards List without I2S DAC
info: CoreCommandRouter::executeOnPlugin: i2s_dacs , getI2SNumber
info: CoreCommandRouter::executeOnPlugin: mpd , getConfigParam
info: CoreCommandRouter::executeOnPlugin: mpd , getPlaybackMode
info: CoreCommandRouter::executeOnPlugin: system , getAdvancedSettingsStatus
error: Upnp client error: Error: This socket has been ended by the other party
error: Cannot set ALSA Volume: Error: Alsa Mixer Error: xcb_connection_has_error() returned true
amixer: Unable to find simple control ‘’,0
info: Starting Shairport Sync
[SpotifyConnect] Restarting Vollibrespot Daemon
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl restart shairport-sync
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl restart volspotconnect2.service
Stopping Shairport Sync - AirPlay Audio Receiver…
Starting Shairport Sync - AirPlay Audio Receiver…
Started Shairport Sync - AirPlay Audio Receiver.
output: No ‘AudioOutput’ defined in config file
output: Attempt to detect audio output device
output: Attempting to detect a alsa audio device
output: Successfully detected a alsa audio device
Stopping Volspotconnect2 Daemon…
Starting Volspotconnect2 Daemon…
Started Volspotconnect2 Daemon.
info: Shairport-Sync Started
vollibrespot v0.2.2 cd96399 2020-10-07 (librespot 08d8bcc 2020-10-07) – Built On 2020-10-07
Reading Config from “volspotify.toml”
[Vollibrespot] : Using Alsa backend with device: softvolume
error: updateQueue error: null
[SpotifyConnect] Vollibrespot Daemon service restarted!
info: CoreCommandRouter::executeOnPlugin: mpd , restartMpd
info: VolumeController:: Setting startup Volume 100
[Vollibrespot] : Connecting to AP “guc3-accesspoint-b-kq86.ap.spotify.com:443”
[Vollibrespot] : Authenticated as “redpatokasea” !
[Vollibrespot] : Setting up new mixer: card:hw:2 mixer:SoftMaster index:0
[Vollibrespot] : Alsa min-db is not SND_CTL_TLV_DB_GAIN_MUTE!!
[Vollibrespot] : Alsa Mixer info min: 0 (MilliBel(0)[dB]) – max: 99 (MilliBel(0)[dB]) HW: false
[Vollibrespot] : Using Alsa linear volume
[Vollibrespot] : Using alsa sink
[Vollibrespot] : Country: “US”
[Vollibrespot] : Metadata pipe established
[Vollibrespot] : Event: Volume { volume_to_mixer: 65535 }
[SpotifyConnect] 100
[SpotifyConnect] Volume: Spotify:100 Volumio: 100
[Vollibrespot] : Fetching autoplay context uri
[SpotifyConnect] A connect session has begun
[Vollibrespot] : Event: SessionActive { became_active_at: 1602690998535 }
[Vollibrespot] : SessionActive!
[Vollibrespot] : Event: PlaybackStarted { track_id: SpotifyId { id: 84920193351677668953104237875269126260, audio_type: Track } }
[Vollibrespot] : Event: PlaybackLoading { track_id: SpotifyId { id: 84920193351677668953104237875269126260, audio_type: Track } }
[SpotifyConnect] Device palyback is active!
[SpotifyConnect] Currently active: mpd
[SpotifyConnect] Stopping currently active service
UNSET VOLATILE
[SpotifyConnect] Vollibrespot Active
[SpotifyConnect] Setting Volatile state to Volspotconnect2
[SpotifyConnect] Currently active: volspotconnect2
[SpotifyConnect] Pushing new state :: true
[Vollibrespot] : Autoplay uri resolved to <“spotify:station:user:redpatokasea:playlist:0fc3QTjYCM3hZP1DGS2D6k”>
[Vollibrespot] : Resolving uri “spotify:station:user:redpatokasea:playlist:0fc3QTjYCM3hZP1DGS2D6k”
[Vollibrespot] : Event: GotToken { token: Token { access_token: “BQB5RZr020RFc_ardXbpXgpt1cBYK7zSCmS3m56P3sNj7rDCFW7bg1L35nXfN0FleRWSyKRETnNORifvBUNGecCL7f2n9e9pZhAT5kKZczo5v-hUmRSykHDfaq_YduEG0trsVLpDP5Ebp6q_SfpbBaeZn-8ipymrfJYCtmVk”, expires_in: 3600, token_type: “Bearer”, scope: [“streaming”, “user-read-playback-state”, “user-modify-playback-state”, “user-read-currently-playing”, “user-read-private”] } }
[SpotifyConnect] BQB5RZr020RFc_ardXbpXgpt1cBYK7zSCmS3m56P3sNj7rDCFW7bg1L35nXfN0FleRWSyKRETnNORifvBUNGecCL7f2n9e9pZhAT5kKZczo5v-hUmRSykHDfaq_YduEG0trsVLpDP5Ebp6q_SfpbBaeZn-8ipymrfJYCtmVk
[Vollibrespot] : Loading with Spotify URI
[SpotifyConnect] Setting VLS device_id: c6e56cf6b68c07041768b06e2f29a439e7724b0e
[Vollibrespot] : Reducing normalisation factor to prevent clipping. Please add negative pregain to avoid.
[Vollibrespot] : Resolved 50 tracks from <“spotify:user:redpatokasea:playlist:0fc3QTjYCM3hZP1DGS2D6k”>
[Vollibrespot] : (354666 ms) loaded
[Vollibrespot] : Event: SinkActive
[SpotifyConnect] Sink acquired
[Vollibrespot] : (404160 ms) loaded
[Vollibrespot] : Event: Pause { track_id: SpotifyId { id: 84920193351677668953104237875269126260, audio_type: Track }, position_ms: 350600 }
[SpotifyConnect] pause
[SpotifyConnect] Young And Foolish
[SpotifyConnect] Not pushing metadata: { active: true, isStopping: true }
[Vollibrespot] : Event: SinkInactive
[SpotifyConnect] Sink released
[SpotifyConnect] Not pushing Pause { active: true, isStopping: true}
[SpotifyConnect] ResolvedStop in e[31m 680s 745.04ms e[39m
[Vollibrespot] : Event: PlaybackStopped { track_id: SpotifyId { id: 84920193351677668953104237875269126260, audio_type: Track } }
[SpotifyConnect] Device palyback is inactive
[SpotifyConnect] Device is paused
