Hi Everone:
I just installed the voumio on my old x86 computer. But it always stucks. Then I checked the journalctl logs. The message report some network problem. Could anyone tell me how to avoid it.
The journalctl message is like this:
Jan 11 20:38:31 volumio sudo[3751]: volumio : TTY=pts/0 ; PWD=/home/volumio ; USER=root ; COMMAND=/bin/journalctl -h
Jan 11 20:38:31 volumio sudo[3751]: pam_unix(sudo:session): session opened for user root by volumio(uid=0)
Jan 11 20:38:31 volumio sudo[3751]: pam_unix(sudo:session): session closed for user root
Jan 11 20:38:34 volumio volumio[3485]: |||||||||||||||||||||||| WARNING: FATAL ERROR ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jan 11 20:38:34 volumio volumio[3485]: Error: connect ETIMEDOUT 173.244.209.150:443
Jan 11 20:38:34 volumio volumio[3485]: at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1159:16) {
Jan 11 20:38:34 volumio volumio[3485]: errno: -110,
Jan 11 20:38:34 volumio volumio[3485]: code: ‘ETIMEDOUT’,
Jan 11 20:38:34 volumio volumio[3485]: syscall: ‘connect’,
Jan 11 20:38:34 volumio volumio[3485]: address: ‘173.244.209.150’,
Jan 11 20:38:34 volumio volumio[3485]: port: 443
Jan 11 20:38:34 volumio volumio[3485]: }
Jan 11 20:38:34 volumio volumio[3485]: ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jan 11 20:38:34 volumio sudo[3763]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/journalctl --since=2024-01-11 20:37
Jan 11 20:38:34 volumio sudo[3763]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jan 11 20:38:34 volumio sudo[3763]: pam_unix(sudo:session): session closed for user root
Jan 11 20:38:34 volumio sudo[3769]: volumio : TTY=pts/0 ; PWD=/home/volumio ; USER=root ; COMMAND=/bin/journalctl -ax
Jan 11 20:38:34 volumio sudo[3769]: pam_unix(sudo:session): session opened for user root by volumio(uid=0)
Jan 11 20:38:35 volumio volumio-remote-updater[480]: [2024-01-11 20:38:35] [error] handle_read_frame error: websocketpp.transport:7 (End of File)
Jan 11 20:38:35 volumio volumio-remote-updater[480]: [2024-01-11 20:38:35] [disconnect] Disconnect close local:[1006,End of File] remote:[1006]
Jan 11 20:38:35 volumio systemd[1]: volumio.service: Main process exited, code=exited, status=1/FAILURE
– Subject: Unit process exited
– Defined-By: systemd
– Support: Debian -- User Support
– An ExecStart= process belonging to unit volumio.service has exited.
– The process’ exit code is ‘exited’ and its exit status is 1.
Jan 11 20:38:35 volumio systemd[1]: volumio.service: Failed with result ‘exit-code’.
– Subject: Unit failed
– The unit volumio.service has entered the ‘failed’ state with result ‘exit-code’.
Jan 11 20:38:35 volumio systemd[1]: Started dynamicswap service.
– Subject: A start job for unit dynamicswap.service has finished successfully
– Support:
– A start job for unit dynamicswap.service has finished successfully.
– The job identifier is 3776.
Jan 11 20:38:35 volumio systemd[1]: dynamicswap.service: Succeeded.
– Subject: Unit succeeded
– Support:
– The unit dynamicswap.service has successfully entered the ‘dead’ state.
Jan 11 20:38:35 volumio systemd[1]: volumio.service: Service RestartSec=100ms expired, scheduling restart.
Jan 11 20:38:35 volumio systemd[1]: volumio.service: Scheduled restart job, restart counter is at 7.
– Subject: Automatic restarting of a unit has been scheduled
– Support:
– Automatic restarting of the unit volumio.service has been scheduled, as the result for
– the configured Restart= setting for the unit.
– Support:
– The job identifier is 3844.
Jan 11 20:38:35 volumio systemd[1]: Stopped Volumio Backend Module.
– Subject: A stop job for unit volumio.service has finished
– Support:
– A stop job for unit volumio.service has finished.
