mpd is now version 0.21 which has the tidal and qobuz plugin
Where is there a howto on setting the Qobuz plugin? I was not able to make it work (esp the app id/key thing TBH).
TIA
Emmanuel
You will still need an API key, which is handed over to companies or projects. So basically this plugin does not change much in fact of end-user streaming services support for MPD. If you’re interested in knowing why it took us so long and what we needed to do to get TIDAL and QOBUZ to Volumio read here: volumio.org/myvolumio-the-new-a … ic-lovers/
Quoting:
Hello everyone,
I’m a new qobuz user and I would like to know if there is a playback quality difference between streaming from bubbleupnp or using native implementation of the service please ?
My setup is : RPI 3 + USB dac
I can only say it sounds fantastic!
The comparison between Qobuz and locally stored FLACs on the NAS in 44/16 or up to 192/24 I found no differences.
I did not stream the native Qobuz app directly to Volumio.
Qobuz is a fantastic thing!
Hi
I use V2.555 on AsusTinkerboard S
I use Tidal, Qobuz, Spotify and Youtube + NOT MyVolumio
The 1st issue is to use Tidal, Qobuz after reboot, need to log out and login again to see Tidal/Qobuz UI.
The 2nd issue is noway to upgrade AsusTinkerboard S eMMC to new version via Auto Mode update. Need re-flash again.
Please have look and hint.
Thank you.
I have my volumio up and running with tidal masters and am pleased with the sound and everything seems to be fine, have had the occasional glitch where it slows but as long as I wait patiently all is well. Having read all the above I only have one question, IS THERE ANYWAY to get it to play at 96/24. During my set up of tidal I had a few issues and asked them and got the response that with a desktop app you can get 96/24 but I can’t find a way to get that to connect to my rpi with hifiberry dac + pro.
Would love to hear a success story!
Fred
Do you use a free Volumio account or one of the payed ones?
I use the free one but only older versions showing the Qobuz/Tidal streaming options.
Using 2.599 these options are going.
Thanks.
Regards,
Ad.
I have the same issue I can not stream from qobuz or tidal to volumio. On spotify is ok, I also have a payed version.
I am using v 2.773
Hello
Please try to unsubscribe from Qobuz access in Volumio, also unsubscribe Volumio Supersdtar or Virtuoso. Then switch off the Volumio and start it again.
Register Volumio Virtuoso or Superstar now and then register Qobuz in Volumio again.
It worked well for me. I use Qobuz with Volumio every day.
I am using the latest version of Volumio. (2,773)
regards
rost21A
How do I subscribe from qobuz in volumio?
I can not find this option
Found it.
Sorry, do not subscribe - logout / login …
Hi
I have logout from qobuz and my volumio from volumio, I have login back to both but I still not see volumio on my phone when I want to stream. I se only my chromecast audio. The same with tidal.
The spotify is ok
Update : from BubbleUPnP I can select the volumio but when I press play I receive an error action failed 501.
Update 1: I can stream tidal to volumio from BubbleUPnP, play ok.
Could you please give me the exact procedure to make it work.
I really like it this volumio and if also qobuz connect will work then it is fabulous
Thanks .
Just a friendly reminder.
Should I see volumio on qobuz app or tidal, near chromecast, on bybblenupneo app I see it.
Hello
Please excuse the delay…
You can find the Qobuz login in Volumio in Settings - Sources - below Tidal.
You will only see this if you are logged in to Volumio with your Virtuoso or Superstar login. (see image)
Greetings
rost21A
Thanks for your response but my issue is that I can not see volumio when I want to stream from Android qobuz app, like I stream spotify with spotify conect… From spotify app
See the picture pls
Ah, sorry, I read it wrong …
Unfortunately, that doesn’t seem to work.
I haven’t been able to stream from the Qobuz app to Volumio yet.
But I love the Volumio GUI, I like it a lot better.
So everything is available in the same interface, my flacs, my radio stations and Qobuz. Perfect for me!
Even if not all functions of the Qobuz app are available.
regards
rost21A
Ok, but this feature is available in volumio like spotify conect or not?
If I am in volumio and if I play a song on qobuz from a Playlist how do I go back to the Playlist? To see all the songs?
