Do you mean these controls meet your requirements?
When I press play on Playlist folder the Playlist starts to play but after the first song it is skipped to another song from another Playlist and why I can not press play only on one single song from a Playlist and then to continue with next song from the same Playlist… This is frustrating…
did you activate random play?
You are right.
But now why 8 can not play just one song from the qobuz Playlist…
Thanks for your continuous support.
În the end volumio support qobuz connect like spotify connect?
Hello everyone,
I wanted to know if there was a possibility to have a plugin for qobuz as we can have for spotify because personally I prefer to use the Qobuz application than the volumio interface? I read all the posts but I did not find an answer.
Thank you in advance for your reply
I’m new to Volumio and am going through evaluation process of the Tidal implementation. Is there any particular reason why all Tidal tracks are output/limited to 44.1KHz? When I play through upnp from my phone (mconnect) I get higher sample rates for the very same track. My hat is HB Digi+Pro.
Cheers,
I’d question whether Volumio should associate itself with discussion/promotion of AudFree.
It’s a product which gets around streaming platforms and turns them into download sites.
This means, inter alia, that royalties will not be paid to artists based on numbers of streams as per the licensing agreements which streaming platforms operate under. Effectively it turns the streaming platforms into piracy platforms.
So even if it looks legit (and to be fair it does), it’s likely legally dubious, and anti-artist.
Given that Volumio has removed mentions of and distanced itself from workarounds for Tidal Connect, I can’t imagine that it’d want to see AudFree being suggested to people on this forum.
I stand to be corrected, of course, but I’d be surprised if so.
@Dr_Endarken
You’re right.
We try to remove such link or post, but sometimes we miss it…
Volumio must stay away from software, website or anything else that promotes such things.
It is done now
