Spotify plugin stops AGAIN :( — only 4.1.3 ever worked
Hi everyone,
I’ve been using Volumio with the Spotify plugin for quite some time now, and I’ve always faced the same issue: “Spotify playback stops automatically after a few minutes/hours”, and I have to manually press Play again.
The only version that never had this issue, was version: 4.1.3 . I used it for several months without a single interruption — it was perfect.
However, two days ago, music suddenly stopped and I couldn’t get it to play again. The Play button wouldn’t respond at all, and on Spotify i cant play too! That’s when I updated to the latest and actual plugin version (4.2.2), which fixed the Play button issue, but unfortunately, the problem of playback stopping after a few hours came back.
So in short:
  • All versions stop playback after a minutes/hours, except the Version: 4.1.3;
  • 4.1.3 only version that doesn’t stop, but recently the Play button stopped worked;
  • 4.2.2 plays, but playback still stops after a while!
Is there any way to:
  1. Prevent Spotify playback from stopping with the current version?
  2. Or download and reinstall the “4.1.3 version” again?
Thanks a lot for your help!
A post was merged into an existing topic: Spotify Issues - We’re working on a fix
