This is a community forum, for support specifically with myVolumio, email techsupport at volumio dot org!
I know you are frustrated, but just wanted to point out Spotify/Spotify Connect are included in the base free/opensource Volumio, and are not part of the freemium myVolumio.
Furthermore, these Spoitfy plugins are based on community developed software, that are not officially supported by Spotify ā so things break. Most of us community devs do this in our free time, so things might be a bit spotty depending on our resources.
While the core Volumio developers will try to fix things when they break, it is unlikely these things get the same priority as paid features of myVolumio.
All that being said, this is most probably Spotify transitioning to newer infrastructure, and related outages. So things should get better as they figure things out.
If this is freeware, then what did I pay $40us for? I understand the Spotify subscription fee and that pays for licensing content.
Um, if you paid for this plugin, then someone has scammed you ā the Spotify plugin is free.
Scammed? My Volumio subscription says Virtuiso. I signed up fro the trial and then was billed after 15 days.
Are you saying I donāt need that plan?
MyVolumio Virtuoso
Use MyVolumio on 1 device
Automatic Sync of Personal items
Remote connection to 1 device
Native TIDAL and Qobuz Integration
TIDAL Connect
CD Playback and Ripping
Alexa Integration
Bluetooth Audio Playback Input
On the Virtuoso plan it says āUse MyVolumio on 1 deviceā, and āRemote connection to 1 deviceā
That implies that to use my Ipad as the user interface I need that plan?
Is that not the case?
i can use any browser in the network to connect to 1 device
in my case rpi you donāt need myvolumio to do thatā¦
but if you want all the extraās of Virtuoso you need itā¦
Ok I just cancelled it. I have been running it on the Safari browser by simply typing in the IP address of the Rpi. Sounds like I was never actually using Virtuoso.
Indeed, you havenāt been using any of the myVolumio features.
The āremote connectionā is to connect to your device from outside your own network ā for example playing dog barking sounds every few hours while you are on vacation
Ok thanks to all here. I was a bit miffed because I paid for the subscription and therefore expected prompt support. As I now understand that RPi is not really officially supported by Volumio, I canātg complain.
I am going to try PiMusicBox on an older RPi3 until this gets sorted out here.
Apparently PiMusicBox wil not run on an RPi4?
The popular problem with the RPi3 is that the USB port shares the buss with the Ethernet interface which is said to degrade the audio. We shall see.
This is incorrect.
The problems that people were experiencing and posted about in this thread are probably changes at the Spotify end.
So I just re-installed 2 devices and they are now working fine. Likely on the spotify end I guess, unless the Volumio install phones home on the boot up and something was messed up there. Iāll look into that another time.
I am a bit concerning because I was doing this to prepare for a party setup and when I did by test run last night this was not working. I was able to use airplay but donāt want to do that during the event. Iāll have to prepare some phones with the spotify playlist downloaded and ready to just plug-in in case I see something similar again.
Iāve used this setup for years with great success and never had such problems. Hopefully it was just a short lived thing. They did not note any issues here: https://twitter.com/spotifystatus
Do you also use an raspberry pi for volumio or what kind of backend do you use ?
Backend?
For control I am using an Ipad.
The DAC is a $30 Ebay China special based on the 1704 chip. I am a hardware EE and I must say they used good parts in the analog section. 1% resistors and a socketed OPAMP so you can replace it if you want. It also has separate power supplies for analog and digital. You need two power transformers which some may see as a disadvantage. But fine for me.
Yes, on raspberry pi. One is on a 4 and other 3 with a hifiberry dac+. Both now seem to be working fine after a standard install (I reflashed the card) and setup of the plugin. I use two different spotify accounts on these so I can use them both at the same time.
The latter I have been using as my main streaming device for years. Often with pre-made playlists, but also with lots of air play from my phone.
I re-flashed the Pi.
But now Spotify will not come up in the menu options after being installed? And the AUTHORIZE page does nothing after authorize is selected.
I just downgraded my Volumio account to free but still have a PREMIUM Spotify account.
After using the spotify plugin succesfully some time, I had the same problem and the error:
SPOP command error: Error: This socket has been ended by the other party
After a fresh restart, spop deamon returned the following:
systemctl status -l spop
..volumio[14059]: ALSA lib pcm_hw.c:1822:(_snd_pcm_hw_open) Invalid value for card
.. volumio[14059]: 2022-01-27 12:31:58 [WARN] libsox: formats.c: can't open output file `plug
hw:volumio,0': snd_pcm_open e
Spop is started with /etc/spopd.conf which contained the following:
[sox]
output_type = alsa
output_name = plughw:volumio,0
After reinstalling the plugin and activating it, it changed back to:
output_name = volumio
This change and a restart (volumio vrestart) solved the problem. So, when you encounter this problem again, try changing the output_name back to volumio in /etc/spopd.conf and restart.
It looks like a logout and relogin in spotify not only changes the spotify_username and spotify_password in /etc/spopd.conf , but also affects the value of output_name!
This problem seems to be fixed in the latest version of the plugin.
same problem here. Fresh install of volumio with whatever is the latest version available for raspberry pi in february 2022. Spotify Connect 2 plugin works, Spotify plugin version 2.0.3 doesnāt work.
Hi, thatās how I went, Spotify couldnāt connect for days. Delete the browser password filler entry, delete the HIGHRESAUDIO usr / pw fields. Spotify then logged in. It helped me, itās reproducible.
