Spotify Connect
Hi All!
since two days I cannot connect to Volumio anymore with Spotify Connect. Version of plugin is 18/02/2018. Volumio is up to date to the last version 2.368.
From Spotify App when I try to connect to Volumio the app says “connecting…” then after a few seconds nothing happen.
Is there some way to see the logs?
Thanks in advance
Spotify Connect stopped working for me also.
This is happening on 3 different RPi’s.
Latest Volumio and latest volspotconnect 2.
Will post logs this evening.
greetings,
L
Hi all,
Spotify just released a breaking update to their connect protocol in their new version of the Android and iOS apps. Should have an update for you all soon!
Cheers
All is said…
We are doing the best to update the plugin.
But it will take some days…
Thanks for the hard work guys!
In the mean time we can still use the old volspotconnect plugin :slight_smile:
Gesendet von meinem Nexus 5X mit Tapatalk
I have uninstalled the old volspotconnect plugin. But the latest volumio release doesn’t allow installation from zip files. How can I still install the old plugin?
Thanks in advance
Connect via ssh to volumio.
Download the plugin via wget
unzip ( unzip has to be installed via sudo apt-get unzip)
And then just: volumio plugin install
Maybe it would be nice if the old plugin will also be added to the official plugins.
I agree, nice idea.
No need to install unzip.
Use miniunzip instead, already installed.
For people who are willing to test with arm devices, ssh into your device and then:
wget https://github.com/balbuze/volumio-plugins/raw/master/plugins/music_service/volspotconnect2/volspotconnect2.zip
mkdir ./volspotconnect2
miniunzip volspotconnect2.zip -d ./volspotconnect2
cd ./volspotconnect2
PS: This is beta – please be gentle :wink:
Edit: changed to point to repo
Sadly no success
Feb 28 16:59:13 volumio volumio[11465]: INFO:librespot: librespot d9deef8 (2018-02-06). Built on 2018-02-06. Build ID: BKb2hWLu Feb 28 16:59:14 volumio volumio[11465]: INFO:librespot_core::session: Connecting to AP "gew1-accesspoint-b-vzpx.ap.spotify.com:4070" Feb 28 16:59:14 volumio volumio[11465]: INFO:librespot_core::session: Authenticated as "thomasfjen" ! Feb 28 16:59:14 volumio volumio[11465]: INFO:librespot_core::session: Country: "DE" Feb 28 16:59:14 volumio volumio[11465]: INFO:librespot::audio_backend::alsa: Using alsa sink Feb 28 16:59:23 volumio volumio[11536]: INFO:librespot: librespot d9deef8 (2018-02-06). Built on 2018-02-06. Build ID: BKb2hWLu Feb 28 16:59:24 volumio volumio[11536]: INFO:librespot_core::session: Connecting to AP "gew1-accesspoint-b-06tq.ap.spotify.com:4070" Feb 28 16:59:24 volumio volumio[11536]: INFO:librespot_core::session: Authenticated as "thomasfjen" ! Feb 28 16:59:24 volumio volumio[11536]: INFO:librespot_core::session: Country: "DE" Feb 28 16:59:24 volumio volumio[11536]: INFO:librespot::audio_backend::alsa: Using alsa sink
Yep - it was using the old binaries - Can you try again? balbuze has updated the repo.
Tried to update, no luck.
INFO:librespot: librspot d9deef8 (2018-02-06). Built on 2018-02-06. Build ID: Bb2hWLu
Feb 28 19:27:37 Volumio volumio[10397]: INFO:librespot: lib espot d9deef8 (2018-02-06). Built on 2018-02-06. Build ID: Kb2hWLu Feb 28 19:27:38 Volumio volumio[10397]: INFO:librespot_core :session: Connecting to AP "gew1-accesspoint-b-x5hh.ap.spot fy.com:4070" Feb 28 19:27:38 Volumio volumio[10397]: INFO:librespot_core :session: Authenticated as "code" ! Feb 28 19:27:38 Volumio volumio[10397]: INFO:librespot::aud o_backend::alsa: Using alsa sink Feb 28 19:27:38 Volumio volumio[10397]: INFO:librespot_core :session: Country: "FI" Feb 28 19:27:47 Volumio volumio[10476]: INFO:librespot: lib espot d9deef8 (2018-02-06). Built on 2018-02-06. Build ID: Kb2hWLu Feb 28 19:27:48 Volumio volumio[10476]: INFO:librespot_core :session: Connecting to AP "gew1-accesspoint-b-n1gh.ap.spot fy.com:4070" Feb 28 19:27:48 Volumio volumio[10476]: INFO:librespot_core :session: Authenticated as "code" ! Feb 28 19:27:48 Volumio volumio[10476]: INFO:librespot::aud o_backend::alsa: Using alsa sink Feb 28 19:27:48 Volumio volumio[10476]: INFO:librespot_core :session: Country: "FI"
Also tried to update, results:
Feb 28 19:39:28 keuken volumio[6909]: INFO:librespot: librespot d9deef8 (2018-02-06). Built on 2018-02-06. Build ID: BKb2hWLu Feb 28 19:39:28 keuken volumio[6909]: INFO:librespot_core::session: Connecting to AP "gew1-accesspoint-b-93gm.ap.spotify.com:4070" Feb 28 19:39:29 keuken volumio[6909]: INFO:librespot_core::session: Authenticated as "movingdots" ! Feb 28 19:39:29 keuken volumio[6909]: INFO:librespot_core::session: Country: "BE" Feb 28 19:39:29 keuken volumio[6909]: INFO:librespot::audio_backend::alsa: Using alsa sink Feb 28 19:39:31 keuken volumio[6938]: INFO:librespot: librespot d9deef8 (2018-02-06). Built on 2018-02-06. Build ID: BKb2hWLu Feb 28 19:39:31 keuken volumio[6938]: INFO:librespot_core::session: Connecting to AP "gew1-accesspoint-b-qsh4.ap.spotify.com:4070" Feb 28 19:39:32 keuken volumio[6938]: INFO:librespot_core::session: Authenticated as "movingdots" ! Feb 28 19:39:32 keuken volumio[6938]: INFO:librespot_core::session: Country: "BE" Feb 28 19:39:32 keuken volumio[6938]: INFO:librespot::audio_backend::alsa: Using alsa sink Feb 28 19:39:35 keuken volumio[6967]: INFO:librespot: librespot d9deef8 (2018-02-06). Built on 2018-02-06. Build ID: BKb2hWLu Feb 28 19:39:35 keuken volumio[6967]: INFO:librespot_core::session: Connecting to AP "gew1-accesspoint-b-ln46.ap.spotify.com:4070" Feb 28 19:39:36 keuken volumio[6967]: INFO:librespot_core::session: Authenticated as "movingdots" ! Feb 28 19:39:36 keuken volumio[6967]: INFO:librespot_core::session: Country: "BE" Feb 28 19:39:36 keuken volumio[6967]: INFO:librespot::audio_backend::alsa: Using alsa sink Feb 28 19:39:39 keuken volumio[6996]: INFO:librespot: librespot d9deef8 (2018-02-06). Built on 2018-02-06. Build ID: BKb2hWLu Feb 28 19:39:39 keuken volumio[6996]: INFO:librespot_core::session: Connecting to AP "gew1-accesspoint-b-xnrm.ap.spotify.com:4070" Feb 28 19:39:40 keuken volumio[6996]: INFO:librespot_core::session: Authenticated as "movingdots" ! Feb 28 19:39:40 keuken volumio[6996]: INFO:librespot_core::session: Country: "BE" Feb 28 19:39:40 keuken volumio[6996]: INFO:librespot::audio_backend::alsa: Using alsa sink Feb 28 19:39:42 keuken volumio[7027]: INFO:librespot: librespot d9deef8 (2018-02-06). Built on 2018-02-06. Build ID: BKb2hWLu Feb 28 19:39:43 keuken volumio[7027]: INFO:librespot_core::session: Connecting to AP "gew1-accesspoint-b-1nkj.ap.spotify.com:4070" Feb 28 19:39:44 keuken volumio[7027]: INFO:librespot_core::session: Authenticated as "movingdots" ! Feb 28 19:39:44 keuken volumio[7027]: INFO:librespot_core::session: Country: "BE" Feb 28 19:39:44 keuken volumio[7027]: INFO:librespot::audio_backend::alsa: Using alsa sink Feb 28 19:39:46 keuken volumio[7063]: INFO:librespot: librespot d9deef8 (2018-02-06). Built on 2018-02-06. Build ID: BKb2hWLu Feb 28 19:39:46 keuken volumio[7063]: INFO:librespot_core::session: Connecting to AP "gew1-accesspoint-b-8m88.ap.spotify.com:4070" Feb 28 19:39:47 keuken volumio[7063]: INFO:librespot_core::session: Authenticated as "movingdots" ! Feb 28 19:39:47 keuken volumio[7063]: INFO:librespot_core::session: Country: "BE" Feb 28 19:39:47 keuken volumio[7063]: INFO:librespot::audio_backend::alsa: Using alsa sink Feb 28 19:39:50 keuken volumio[7092]: INFO:librespot: librespot d9deef8 (2018-02-06). Built on 2018-02-06. Build ID: BKb2hWLu Feb 28 19:39:51 keuken volumio[7092]: INFO:librespot_core::session: Connecting to AP "gew1-accesspoint-b-2bvn.ap.spotify.com:4070" Feb 28 19:39:52 keuken volumio[7092]: INFO:librespot_core::session: Authenticated as "movingdots" ! Feb 28 19:39:52 keuken volumio[7092]: INFO:librespot_core::session: Country: "BE" Feb 28 19:39:52 keuken volumio[7092]: INFO:librespot::audio_backend::alsa: Using alsa sink Feb 28 19:39:54 keuken volumio[7128]: INFO:librespot: librespot d9deef8 (2018-02-06). Built on 2018-02-06. Build ID: BKb2hWLu Feb 28 19:39:55 keuken volumio[7128]: INFO:librespot_core::session: Connecting to AP "gew1-accesspoint-b-kqcn.ap.spotify.com:4070" Feb 28 19:39:56 keuken volumio[7128]: INFO:librespot_core::session: Authenticated as "movingdots" ! Feb 28 19:39:56 keuken volumio[7128]: INFO:librespot_core::session: Country: "BE" Feb 28 19:39:56 keuken volumio[7128]: INFO:librespot::audio_backend::alsa: Using alsa sink Feb 28 19:39:59 keuken volumio[7164]: INFO:librespot: librespot d9deef8 (2018-02-06). Built on 2018-02-06. Build ID: BKb2hWLu Feb 28 19:40:00 keuken volumio[7164]: INFO:librespot_core::session: Connecting to AP "gew1-accesspoint-b-rmlx.ap.spotify.com:4070" Feb 28 19:40:00 keuken volumio[7164]: INFO:librespot_core::session: Authenticated as "movingdots" ! Feb 28 19:40:00 keuken volumio[7164]: INFO:librespot_core::session: Country: "BE" Feb 28 19:40:00 keuken volumio[7164]: INFO:librespot::audio_backend::alsa: Using alsa sink Feb 28 19:40:03 keuken volumio[7193]: INFO:librespot: librespot d9deef8 (2018-02-06). Built on 2018-02-06. Build ID: BKb2hWLu Feb 28 19:40:03 keuken volumio[7193]: INFO:librespot_core::session: Connecting to AP "gew1-accesspoint-b-t2ww.ap.spotify.com:4070" Feb 28 19:40:04 keuken volumio[7193]: INFO:librespot_core::session: Authenticated as "movingdots" ! Feb 28 19:40:04 keuken volumio[7193]: INFO:librespot_core::session: Country: "BE" Feb 28 19:40:04 keuken volumio[7193]: INFO:librespot::audio_backend::alsa: Using alsa sink Feb 28 19:40:07 keuken volumio[7232]: INFO:librespot: librespot d9deef8 (2018-02-06). Built on 2018-02-06. Build ID: BKb2hWLu Feb 28 19:40:07 keuken volumio[7232]: INFO:librespot_core::session: Connecting to AP "gew1-accesspoint-b-6417.ap.spotify.com:4070" Feb 28 19:40:08 keuken volumio[7232]: INFO:librespot_core::session: Authenticated as "movingdots" ! Feb 28 19:40:08 keuken volumio[7232]: INFO:librespot_core::session: Country: "BE" Feb 28 19:40:08 keuken volumio[7232]: INFO:librespot::audio_backend::alsa: Using alsa sink
weird thing is that i have another raspberry pi 3 with libreelec where i have librespot running, which is working fine.
edit: seems the librespot plugin was updated already (maybe you already know this)
https://forum.libreelec.tv/thread/8438-librespot-addon/?postID=82979#post82979
please, wait a little bit… In your log is see an old version of librespot. Are you installing it via ssh?
balbuze,
Yes,
i did:
wget https://git.io/vAXK0 -O volspotconnect2.zip mkdir ./volspotconnect2 miniunzip volspotconnect2.zip -d ./volspotconnect2 cd ./volspotconnect2 volumio plugin install
and
wget https://git.io/vA1f1 -O librespot.zip miniunzip librespot.zip chmod +x librespot rm librespot.zip
I had the same, but thought i installed the wrong plugin file, because the date of librespot wasn’t changed.
I downloaded the latest plugin from github (updated a few minutes before).
ok I understand…
wrong path…
should be ok with :
wget https://github.com/balbuze/volumio-plugins/raw/master/plugins/music_service/volspotconnect2/volspotconnect2.zip mkdir ./volspotconnect2 miniunzip volspotconnect2.zip -d ./volspotconnect2 cd ./volspotconnect2 volumio plugin install
Do not install librespot ! It is done by the plugin
Seems to be working, thanks !
had to delete the ./volspotconnect2 dir because it already existed but now it works again :slight_smile:
