which device do you use (RPI B, RPI2, RPI3)
could you past the content of /data/plugins/music_service/volspotconnect/spotify-connect-web/startconnect.sh ( replace your credentials by XXX) ?
I am using a RPI 3.
volumio@volumio:~$ /data/plugins/music_service/volspotconnect/spotify-connect-web/startconnect.sh
Loading Spotify library...
File "loader.py", line 3, in <module>
File "runpy.py", line 180, in run_module
File "runpy.py", line 72, in _run_code
File "/data/plugins/music_service/volspotconnect/spotify-connect-web/main.py", line 14, in <module>
from connect import Connect
File "/data/plugins/music_service/volspotconnect/spotify-connect-web/connect.py", line 9, in <module>
from console_callbacks import audio_arg_parser, mixer, error_callback, connection_callbacks, debug_callbacks, playback_callbacks, playback_setup
File "/data/plugins/music_service/volspotconnect/spotify-connect-web/console_callbacks.py", line 104, in <module>
mixer = alsa.Mixer(args.mixer, **mixer_card_arg)
alsaaudio.ALSAAudioError: Unable to find mixer control Digital,0 [hw:5]
Failed to execute script loader
Established under name 'Volumio'
Using Volume without any problems with the STU Output (airplay, web radio working)
thank you but I need the content of startconnect.sh do
cat startconnect.sh
please (remove credentials)
I am sorry that I have to ask, what do you mean with
The output is
The content of start connect.sh is
do you use the very last version of volumio ? 2.001 ? If yes, try to remove "mixer_device_index 5 " from startconnect.sh and enter
systemctl restart volspotconnect
to see what happens…
If not the last version of volumio please upgrade (go in system and check for update)
I am using the latest Volumio Version.
I did the suggested change. Output are as followed
alsaaudio.ALSAAudioError: Unable to find mixer control Digital,0 [default]
On thing I stumbled upon is, that the only mixer I can chose is “Hardware”
and you see a “digital” mixer, don’t you ? If it works in Volumio, I can’t see why it failed here… I tested it with a USB dac and it works with no problem (mixer is called PCM) with hw:5 as output… Of cours I guess you saved output and mixer serveral times…
In alsamixer, do you see a mixer called Digital for your DAC ?
Just a idea : save mixer, go in startconnect.sh and remplace “Digital” by “PCM” and systemctl restart volspotconnect…
No, I can only select Hardware as a Mixer. There is no option for a software mixer
Ok, after editing startconnect.sh VOLUMIO shows up as a Spotify connect device. Unfortunately no sound output yet. I guess we are getting closer to the problem
./spotify-connect-web --username 'XXXXX' --password 'XXXX' --bitrate 320 --name 'Volumio' --playback_device hw:5 --mixer PCM # &
avahi-publish-service 'Volumio' _spotify-connect._tcp 4000 VERSION=1.0 CPath=/login/_zeroconf
running /data/plugins/music_service/volspotconnect/spotify-connect-web/startconnect.sh
min_volume_range: 0.0
Using libspotify_embedded version: release-esdk-1.20.0-v1.20.0-g594175d4
SpInit: 0
playback_volume: 56360
corected_playback_volume: 85
public key: XXXXX
device id: XXXXX
remote name: Volumio
account req: PREMIUM
device type: AUDIODONGLE
File "/data/plugins/music_service/volspotconnect/spotify-connect-web/main.py", line 259, in <module>
http_server.serve_forever()
File "gevent/baseserver.py", line 347, in serve_forever
File "gevent/baseserver.py", line 291, in start
File "gevent/pywsgi.py", line 1222, in init_socket
File "gevent/server.py", line 80, in init_socket
File "gevent/server.py", line 91, in get_listener
File "gevent/server.py", line 177, in _tcp_listener
File "<string>", line 1, in bind
socket.error: [Errno 98] Address already in use: ('', 4000)
Ok no problem with hardware mixer. But what is its name in volumio? Master digital pcm or something else. And in alasmixer ?
In Volumio the name is PCM.
In AlsaMixer Xonar Essence STU, Chip USB Mixer, Item PCM
But somehow right now there is no sound at all ![]()
Sorry for this late answer… there is something that can’t be for me : having a pcm mixer and digital in the plugin as it use the value returns by volumio… So are you sure you saved the mixer setting in volumio ?
Yep, I saved it at least a couple of times. I restarted Volumio, I changed the /data/plugins/music_service/volspotconnect/spotify-connect-web
./spotify-connect-web.sh file. Although it seems to be overwritten by some other file because the --mixer_device_index 5 line has been added a couple of times again. With it deleted Volumio shows up in Spotify as a connected device.
The plugin add the --mixer_device_index because with other dac it does not work… I have to make a sort of exception for this case…
So, could you fill or correct the following ( even if you already answers, please fill it if you want I try to make it work…)
your device rpi 3
your dac : usb model model xxx
mixer shown in volumio :
the content of startconnect.sh :
and if when removing --mixer_device_index :
the result : working but no sound
paste the result of amixer -c5 controls
and anything that may help…
Thank you so much for your help!
your device rpi 3
volumio@volumio:~$ aplay -l
Subdevices: 8/8
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
Subdevice #7: subdevice #7
card 0: ALSA [bcm2835 ALSA], device 1: bcm2835 ALSA [bcm2835 IEC958/HDMI]
Subdevices: 1/1
card 5: STU [Xonar Essence STU], device 0: USB Audio [USB Audio]
Subdevices: 0/1
mixer shown in volumio : Mixer type: Hardware; Mixer Control Name: PCM
the content of startconnect.sh before removing mixer_device_index 5 :
cd /data/plugins/music_service/volspotconnect/spotify-connect-web
./spotify-connect-web --username 'XXXX' --password 'XXXX' --bitrate 320 --name 'Volumio' --playback_device hw:5 --mixer PCM --mixer_device_index 5 # &
SpInit: 0
File "/data/plugins/music_service/volspotconnect/spotify-connect-web/main.py", line 56, in <module>
connect_app = Connect(web_error_callback, web_arg_parser)
File "/data/plugins/music_service/volspotconnect/spotify-connect-web/connect.py", line 87, in __init__
lib.SpPlaybackUpdateVolume(mixer_volume)
OverflowError: integer 66190 does not fit '16-bit unsigned int'
and after removing --mixer_device_index :
./spotify-connect-web --username 'XXXX' --password 'XXXX' --bitrate 320 --name 'Volumio' --playback_device hw:5 --mixer PCM # &
SpInit: 0
playback_volume: 65535
corected_playback_volume: 100
public key: XXXXX
device id: XXXXX
volumio@volumio:~$ amixer -c5
Simple mixer control 'PCM',0
Capabilities: pswitch pswitch-joined
Playback channels: Mono
Mono: Playback [on]
Have you noticed that amixer -c5 shows a mono setting ?
I did notice. To make sure I did a new set-up and installed the plug in Version from 01.10.16. It is working flawlessly. The output of a mixer -c5 hasn’t changed. It shows mono but it is playing stereo. Unfortunately my linux knowledge is not as good as it should be to solve this kind of problem
@balbuze: thanks for the plugin, finally working Spotify Connect with Volumio! Even with the Raspberry 1 it works.
However (you saw that coming?) startup of the connect service fails with elaborate passwords (containing special characters).
If I might suggest, you could change in the file /data/plugins/music_service/volspotconnect/volspotconnect.tmpl the following passage:
… --password ‘${password}’ … to … --password ‘’${password}’’
(enclosing escaped backslashes…)
Hope that helps further,
sincerely,
Chris
Thank you for the tip even if I thought it was solved. … you are the first to report using it on a RPI 1! I have prepared a new package (the big one downloaded during install) because there is some problem to remove it… How long was install? What is your dac?
