Is there in Volumio a way to speaker setup like Roon or HQPlayer?
you mean something like this?
Volumio comes with a Roon Bridge plugin, but I don’t remember if you need to install and turn it on. Look at Plugins in the Volumio main menu.
After activating the plugin, your Volumio device should be listed in Roon’s settings (Audio section), and you need to enable it. After enabling, you will can use it like a regular Roon endpoint and select it for output when you play music.
I may be wrong, but I don’t believe it is currently possible to use HQPlayer with Volumio. There are other systems that will run Roon Bridge and HQPlayer together.
Thank you. I know the discussion about HouseCurve. But what i’m looking for is a setup like speaker setup in Roon.
Thank you, but i want to use Volumio not Roon. But the Speaker Setup of Room I like it. So I’m looking for a plugin or a software that offers a service with this options
Thank you very much.
Fusion dsp is internal to Volumio software? Also in free option?
Is there some practible connection between Volumio and Daphile?
yes, plugins are free of charge.
For LMS there’s a Squeezelite plugin, not sure if it works on Daphile, never tested it. But since Daphile uses LMS, I expect it will.
Otherwise there is always UPnp/DNLA
Thank you.
But if I would use Daphile like UI and then sending to Volumio and apply the plugins of Volumio, is this possible?
For reference, here is a guide to FusionDSP:
Thank you very much
Thank you. I didn’t understand. Do you have in same chain volumio and foobar2000?
Where does Foobar2000 all the sudden come from?
Sorry, Daphile
Yes as that was your ask.
Using LMS (I am NOT a Daphile fan) and play it to a Volumio device.
Thank you. Is it necessary a Volumio hardware or can i use it with Volumio Software
you need HW to run Volumio as Volumio is an OS.
a rPi3, rPi4, rPi5, Motivo, Rivo, Primo, X86, …
Yes I’ve got a intel pc.
Don’t know if would be possible also AMD
