I upgraded to V 2.799 and had to disable SimpleEqualizer to have sound.
I2s dac hw number changed. Chances are that enabling and saving conf will solve your issue
Ok, now working fines.
I have the same problem. After the new update (799) i have no sound.
I did a complete reset, and it worked. But when i install SimpleEqualizer the sound is gone and i have to redo everything.
I need the Equalizer, please help.
HiFiBerry DAC+ Pro RCA met Spacers with Raspberry Pi 4 Model B - 4GB
Greetings,
Patrick
Hello!
Can please try the following :
Remove the plugin.
Set your Dac and volume mixer.
Reboot
Test
install the plugin
enable it
reboot
test
let me kow
Hello balbuze,
I’ve tried this allready.
When i did a reset and set the Dac and other settings i have sound. When i install after that the plugin the sound is gone. Reboot doesn’t help. There is no sound at all, no radio, no tidal not even the startup sound. When i put back “the original Dac” settings the sound is still gone. When i remove the plugin i still have no sound. I have to do a reset to have sound again without Equalizer.
There is a second Equalizer, it has the same problem.
Greetings,
Patrick
when you disable or remove the plugin, you may have to set the dac and mixer to be able to play something.
can you send your log using when plugin is enable: https://volumio.github.io/docs/User_Manual/Sending_logs_for_troubleshooting.html
and if possible the content of /etc/asound.conf and /data/configuration/audio_interface/alsa_controller/config.json
thanks
I shall do upcomming weekend. I am on a short vacation at this moment.
Thank you for willing to help!
Hope this would not be standard procedure after any Volumio update.
We as Volumio can have control of Volumio itself and check everything is fine for each update.
With plugins this becomes next to impossible to test everything and this is demanded to plugins authors…
We’re working to incorporate a standard way to edit audio out for plugins, so those problems won’t happen again.
I have done as asked. You have the report.
It is still not working for me.
I am going to reinstall again, then i have sound but without equalizer. I hope this bug is solved soon in a quick comming new version update.
Hope to hear from you.
Greetings,
Patrick
You have the report. I’ve send it a few days ago. I hope to hear.
Greetings,
Patrick
The new update didn’t fix the problem…
Greetings
Patrick
hello
where is you log?
can you give the link here please?
TY
Here is my log report after Simple EQ plugin is made Active. Thanks for all your help.
http://logs.volumio.org/volumio/q1UUgnA.html
Here is my log report after Simple EQ plugin is made NOT Active.
Have you removed the plugin, reboot, configure output and volume mixer and reinstall the plugin?
I see an error with lib_asound that appears when Volumio is updated. It brakes something with this lib. The only is to reinstall the plugin.
Let me know
Edit: you may have to do
sudo apt remove libasound2-plugin-equal
Before reinstalling the plugin.
Followed your instructions including the sudo apt remove command. Still no sound.
Have you reinstalled the plugin after that? I see
ALSA lib conf.c:3523:(snd_config_hooks_call) Cannot open shared library libasound_module_conf_pulse.so
As if it was not installed.
If this the case, what return
sudo apt install libasound2-plugin-equal
What it working before with your hw?
