Select a music folder in a usb
Volumio Information
Volumio Version: latest
Hardware: pi 3
DAC: hifiberry dac plus
Is there a way to select individual drives for the library or even folder for the library content.
I have multiple usb drives one used for backing up all my music so obviously I don’t need this to be scanned or my library would have doubles of everything…
There’s no way to select but folders can be excluded from update →
With much playing around there is a way you can select a specific folder.
By editing the mpd.conf file to point to the specific folder you want
The default one is
Var/lib/mpd/music/
In that directory you will see INTERNAL NETWORK and USB
if you have one folder on one usb you use then I found it works just fine adding that folder.
Var/lib/mpd/music/USB/name of your drive/ name of folder/
