The AUDIOPHONICS DAC I-Sabre ES9038Q2M cannot be connected, does not find a DAC, have as Sabre ES9028Q2M does not work either, can someone help me?
not needed is included in volumio
thanks,
but where I have to added the line.
I have only the software from volumio
best regards
Peter
it strange that it’s still not added because it’s a very old post
i will ask around if it’s already included in the dac’s list
tnx to darmur he checked for me if it’s included
your dac is included in volumio.
turn i2s on and select your dac.
Thank you for all,
it is not included because it is an Sabre ES9028Q2M
I have an Sabre ES9038Q2M
the diffenrence is 38
And get no connection…
the settings applied for Audiophonics I-Sabre ES9028Q2M should work also on Audiophonics I-Sabre ES9038Q2M, because they make use of the same dt-overlay (i-sabre-q2m).
please try to test your system with another OS (RaspiOS), I suspect you have a hardware problem that prevents your setup to work with Volumio
