I have just received a brand new Volumio Rivo streamer. It is going to play with a Merason Frerot DAC via Supra Excalibur USB. My plan is to use the Volumio 3 music app.
But I`m having a problem. I have installed everything. The Rivo/Volumio 3 app can see my Merason Frerot DAC. But then it lock the system with the message: “The selected output device is not avaliable”
Its not the USB cable that is causing the problem. Have also tried using a standard printer cable. Same result. So the issue is elsewhere.
As I have been using the Merason Frerot with the Innuos PULSEmini - 100% stable without any issues the Merason isn’t the problem either. For this particular reason I suspect two things:
1: The Merason Frerot isn’t compatible with Volumio for some reason?
2: I have received a faulty Volumio Rivo? (Had external antennas so I can conclude that its from the 1-3 batch)
This is Davide from tech support.
We can continue to make progress on your open ticket by gathering all the necessary information to delve deeper into the issue. Kindly respond to my ticket comment, and I will pose additional technical questions to aid in our investigation.
Likely because it is Amanero based.
No need to check the following as Volumio will support the DAC, but without DSD (DAC does not support it).
[edited: following not applicable]
In case you can give us the vender id and product id, it can be checked.
For that you need to have the DAC connected, then ssh into the Rivo and do
I haven’t the Rivo streamer as it is on its way back to the dealer here in Denmark. So I can`t provide info for now
I thought it was supposed to be plug and play! I have owned streamers from SOtM, Lumin and Innuos. No issues. Don`t know if I will give the Rivo another chance? One issue often follows another issue. Have to give this some serious thought
It is plug and play with nearly all USB Class 2 DACs, as long as DSD is not concerned. For DSD, the DAC needs to be registered into the usb audio driver (many are, some are not).
In your case there is no DSD, so be assured, the DAC will work.
No, i’m a community contributer.
I have hardly seen any USB DAC which did not work with the standard linux usb audio driver.
The Merason appears to be based on an Amanero interface, there are several DACs using this and they work fine.
My suspision is that the issue is on the Rivo I received. As I read Your posts another Rivo unit would most likely not have this issue. Is this conclusion correctly understood?
I can see that a log could have made a difference. If I am to try the Rivo again I have to have 100% reassurance that the Rivo will work flawlessly with my Merason DAC. Best case scenario is that its going to be plug and play without need of tecnical support as the Innuos PULSEmini has been.
I do not exspect You to give me the reassurance gkkpch
Im hoping that Volumio can give me 100% reassurance that Merason and Rivo can work flawlessly together? Otherwise its pointless as I think it should be plug and play as with the other streamers I have owned until now.
As for now my dealer in Denmark is going to receive the Rivo I had on Monday. Then We will find out if it was a faulty unit?
Until then it would be nice though if Volumio could give me 100% reassurance that it will work out with the Merason ?
It would be nice if Volumio help center could answer this question. I have been placing this both on email and here on the community. Now I will place it again in hope of an answer!
It is a simple Yes/No question
Can Volumio give me 100% reassurance that Merason and Rivo can work flawlessly?
