REV5 - Palani Acoustic DIY HiFi Streamer
Hello dear community :slight_smile:
After reading and learning a lot here, I also had to build myself an enclosure :slight_smile:
The streamer runs under rpi4 4gb , 7.9 Touch, a power supply that powers everything individually, a clone of Allo Boss DAC…so nothing wild yet :slight_smile:
I will upgrade the components in time, of course I will also work on new designs of enclosures, I could already build the next one, it’s a lot of fun :slight_smile:
Today i finished the back wall with the connection terminals
An illuminated sign has been installed on top…
Have fun looking…Aiello
awesome!!!
Awesome. How did you attach the display to the front panel?
I cut all the parts with my laser, and the front consists of a carrier front and a visible front.
I still have to correct something in the title line
Hi, what kind of laser do you use ? LED or CO2 ?
I’ve an Sculpfun S10 - is it possible with that one ?
Best Regards
Josef
Edit: im quite new to lasers….
DIY C02 LAser 1600x1400mm travel :slight_smile:
https://www.youtube.com/channel/UCAHuhWuFQtrraxZjYvFj_Rg
Ah ok - think i have to move to a CO2 also….
Thank you
i built a new case, with slot in cd, and bigger lcd :slight_smile:
you made something beautiful, I love it!
thank you very much…will improve it further
phase 2 has started, new parts :slight_smile: …
I see you’ve been lining the pockets of IanCanada!
His stuff is very good.
yes i think they are the best parts you can get
EMC/EMI shielding copper mods…
https://www.youtube.com/@tryfidelityaudio?sub_confirmation=1
been at work again :hammer_and_wrench: :blush:
Here and at DIYAudio, I see,
Great work, and compliments from the master!
@ Yatsushiro Yes, it was like a knighthood for me :slight_smile:
the LifePo4s have arrived :slight_smile:
Inner covers ready…unfortunately it doesn’t fit in the back of my built case by 7-5 mm anymore…but not too bad, as I wanted to design a new one anyway :slight_smile:
