Volumio 3 Issues?
I bought the premium version to use on the raspberry, I logged in but the raspberry doesn’t register. I can’t use premium features.
Wheaten
February 22, 2023, 10:06am
2
If you login to: Volumio - The Music Player
Do you see your device there? If yes press the green play button on the webpage.
Hi thanks for the help, it doesn’t show
Wheaten
February 22, 2023, 10:00pm
4
And you did us the same credentials within Volumio?
Wheaten
February 22, 2023, 10:20pm
6
are these option enabled (you can turn them on and off) in sources?
Only these items.
I used it some time ago, it always worked very well. But this time it’s like this.
I’ve done 3 installations and nothing.
Wheaten
February 22, 2023, 10:42pm
9
@volumio , @DED
Can you guys take a look here. Premium user with no access to the paid features.
@Edmar_da_Silva_Garci
You might want to log a ticket, as paying customer you’re entitled to first line support.
https://volumio.atlassian.net/servicedesk/customer/portal/1/group/1/create/26
