Qobuz: Error No Results
Today I tried to play music from Qobuz in Volumio bit I got an error message of: No Results. I logged off and logged in but no change. What can be the reason?
Volumio 3 Issues?
We are seeing some erratic behaviour which we are trying to fix.
In which country are you located?
Germany
We are experiencing some issues in our infrastructure, which we are working hard to solve ASAP.
Sorry for the inconvenience
Update: after about 3 hours from the reported malfunctions we were able to track down the issue and fix it.
It was a misbehaving network configuration on our infrastructure provider.
Thanks for the cooperation and sorry about the inconvenience
Hi
I have the same issue: trying to play music from Qobuz - and the banner says: “no results”. I live in Switzerland (if that should be important).
A few days ago, everything worked fine, no updates since then.
The error has disappeared (as quickly as it appeared)
Thanks for your report, we are investigating it.
