QOBUZ Connect integration on VOLUMIO streamers
the problem is not related to how old the kernel is, but if the driver for a specific device has a certain function or not.
anyhow, even if the driver does not have that function implemented, keeping multiroom enabled will solve the problem
Let’s tackle that when this becomes apparent. There is a migration path to kernel 6.1 (minimum), currently blocked by on/off button killer criterium with N2’s
did the offer go out?
I have checked my emails but could not find anything.
Hi Warren,
today we ironed out the last issue preventing us from doing the offer. This email will go out next week, thanks for your patience.
Michelangelo
No problems. Thanks for the update.
Warren
@Warren_McDonald the email with the offer just went out.
Thanks for your patience on this and hope this makes you guys on Virtuoso happy.
We really appreciate you being with us for all this time, and even if it took longer than anticipated we really wanted to make you happy.
i use a raspi 4 and problem continues with multiroom on. maybe a bit better but then starts skipping again. I have rebooted qobuz and volumio. I gave up and just use volumio without qobuz connect. Occasionally I might get a song and search for more info and it tells me I have to upgrade when I’ve already done it.
Hello @elamar
can you please send us a log link saved just after the skipping issue?
How to send a log link for a bug report?
Thank you
Best
Davide
VOLUMIO TECH SUPPORT
just did
Please copy/paste the HTML log link here in this thread
Davide
Qobuz android app doesn’t display any device, and when inspecting the logs, the service looks crashing and restarting in loop… fresh install from yesterday. What have been wrong?
http://logs.volumio.org/volumio/1qxB8Vf.html
I cannot get Qobuz Connect to work (using Qobuz on iPhone as a controller), I tried both a Raspberry Pi4 and a x86 on a Celeron fanless pc but it does not work at all: when I start an album, it quickly skips over all tracks without playing any. Is Qobuz connect working for anyone recently or is it broken with the newer version of Qobuz? I tried both with multiroom on and off on both systems.
Is working on Android and Windows.
