Since a while Qobuz Connect with my Pi4 behaves strange. Stopping or pausing does not work, in Volumio AND in the Qobuz App. The music will not end. Ideas?
Greetings from Germany!
metro
June 18, 2026, 5:12pm
2
Check if Volumio’s Multiroom Playback setting is turned on. Qobuz Connect seems to need it turned on even if you don’t use multiroom. See this:
Prerequisites
Volumio Information
Volumio Version: 4.119
Hardware: Raspberry Pi 4
Steps to Reproduce
Issue 1: Pressing pause causes skip to next track
Perform the following steps on the native Qobuz app (mobile or computer):
Play an album
Select Volumio running on RPi as the output device (Qobuz Connect)
Press pause
Result: playing skips to the next track instead of pausing
Issue 2: Play queue repeats after playing the last track
Perform the following steps on the native Qobuz app (mo…
