Hi there,
I recently purchase a QNAP NAS (ts-212) update with last firmware and I started to add several FLAC files inside.
I also set the NAS to shutdown at 1AM and restart at 10.30PM.
The NAS has a static IP
But, at every restart of the NAS Volumio doesn’t recognize the nas drive and I have found a workaround, bit annoying: in the source folder on Volumio I have to edit my path to the drive, click on “save” and magically the drive is recognized.
I am using a Nvidia Shield with Kodi, and there is no problem at every startup to recognize the drive
I also try to add vers=2.0 in the option field but without result
Yes, I tried the NFS mode but the NAS is not recognized. With CIFS the NAS is recognized.
So is there an option to work with the NAS without save every time I want to access?
How do you set everything?
Many thanks
I have just made a working cifs share on my Synology NAS. I rebooted the NAS, and the share was found successully by Volumio.
What I suggest you do is reboot your Volumio device and your NAS, and then post a system log after both have rebooted and you are sure that the share has not been found.
I found a partial solution to my problem, following this post (20/23):
I set to NFS the share in Volumio, and a shared path in my QNAP NAS.
But there is a problem.
Volumio doesn’t recognize the NAS folder when NAS wake up itself.
If I reboot Volumio when the NAS is active, the NAS folder is correctly recognize
Any solutions?
My goal is not keep active 24/24 the NAS as I wrote some post up before
Same comments as my last post: I did not make a new share, because I normally use NFS anyway, but the share is always refound when the NAS is rebooted. A system log would be helpful.
This morning Volumio doesn’t recognize the NAS power on, appear a red window with “Error: failed to decode /var/lib/mpd//music/NASpath; Failed to open /var/lib/mpd/music/NASpath; No such file or directory”
the NAS has a static IP: 192.168.1.8
Nothing at all to see in the logs. Volumio reports trying 4 times to mount the share, and finally gives up.
Apr 27 07:02:55 volumio volumio[891]: info: Cannot mount NAS music at system boot, trial number 4 ,retrying in 5 seconds
Apr 27 07:03:00 volumio sudo[2938]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/mount -t nfs -o ro,soft,noauto 192.168.1.8:/Multimedia/MUSICA /mnt/NAS/music
There is no explanation of why it can’t connect, which leads me to suspect that the problem might well lie at the other end.
I suggest that you look at the logs on your NAS for further clues, and also try the QNAP support forum.
I did do a quick Google for your NAS and saw a couple of similar problems, but back in 2018. One post was to reconfirm the NFS permissions after reboot, but obviously that isn’t a practical solution. Let us know how you get on, because there will be others with similar problems.
Well, first of all, thank you very much for your support!
Maybe, I can try a different path:
If I program the NAS to wake up before power on Volumio, maybe at the boot Volumio itself could mount correctly the NAS
I’ll let you know
