Hello @nerd !
Is there much left to do, test and program before we can have a release candidate up and running? I think many of us users are really looking forward to it. Thank you very much for your work!
kind regards / C
Hello @nerd !
kind regards / C
Hey @ClaesM,
Good question. Right now the biggest blocker is the metadata update race condition that causes issues in multiroom, UPnP and queue handling. This needs to be fully understood and fixed before we can declare a release.
Apart from that, the heavy lifting is done. The Bookworm backend, kernel, drivers, and plugins are largely stable, with remaining work focused on polish, regression checks, and edge-case handling. Once the race condition is resolved and regression-tested across platforms, we can move towards a release.
However @volumio has the final say.
Hey @Shlee,
Thanks for the clear report. The reason that no one has replied to your questions yet: to triage this properly I need a few concrete details:
Once we have the log URL and the above, we can pinpoint whether this is chromium kiosk state, GPU memory, or a UI asset load timing issue.
Blockquote Right now the biggest blocker is the metadata update race condition that causes issues in multiroom, UPnP and queue handling. This needs to be fully understood and fixed before we can declare a release.
Ok, I understand. Then I just can hope that everobody involved in Volumio development @volumio will work hard to solve and fix this.
Regards / C
| VolumioOS ver. | Debian base |
| v2.xxx | Jessie |
| v3.xxx | Buster |
| v4.xxx | Bookworm |
| v5.xxx (TBD) | Trixie (prototyping phase) |
I canât make my new Waveshare 11.9 DSI touch display work with 4.022 in my RPi 4 rev 1.5 with 2 GB. It works with last 3.832, it works with Raspberry OS, and it works with RPi5 and 4.022 without problems, but I havenât been able to see absolutely nothing with RPi 4 and 4.022. Not even backlighting. Tested everything I found in the forum, but without any success.
Device: Raspberry Pi 4B Rev. 1.5 2GB
Storage: MicroSD (eMMC 32GB)
Volumio version: 4.022
Log link: http://logs.volumio.org/volumio/w5jUcKi.html
Problem: Waveshare 11.9 Touch Display not working. It works on 3.832, it works wit Raspberry OS and it works with 4.022 and RPi 5, but not with RPi 4 and 4.022
Display device: https://www.waveshare.com/wiki/11.9inch_DSI_LCD
I donât know what else I can provide. Iâve seen the Xorg.0.log and both the HDMI and the DSI displays appear as connected (nothing is connected to any HDMI), so I disabled HDMI in userconfig.txt and the log changed to:
[ 38.956] (II) modeset(0): Output DSI-1 using monitor section DSI-1
[ 38.956] (**) modeset(0): Option "Rotate" "normal"
[ 38.986] (II) modeset(0): EDID for output DSI-1
[ 38.989] (II) modeset(0): Printing probed modes for output DSI-1
[ 38.989] (II) modeset(0): Modeline "320x1480"x60.2 50.00 320 380 440 500 1480 1540 1600 1660 (100.0 kHz eP)
[ 38.989] (II) modeset(0): Output DSI-1 connected
[ 38.989] (II) modeset(0): Using exact sizes for initial modes
[ 38.989] (II) modeset(0): Output DSI-1 using initial mode 320x1480 +0+0
[ 38.989] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 38.989] (==) modeset(0): DPI set to (96, 96)
But still nothing in the display.
Thanks for this great piece of software. Best regards.
Edit. Another Waveshare DSI display (7inchC) works perfectly with the same RPi4 and 4.022
Hey @aluisperezh,
Your log shows repeated touchscreen I2C errors from the Waveshare driver:
ws_touchscreen 10-0045: I2C write failed: -5.
That points to a touch connectivity or power issue on I2C bus 10 at address 0x45, not to KMS mode setting itself.
Config looks correct for this panel on Pi 4:
dtoverlay=vc4-kms-dsi-waveshare-panel,11_9_inch plus vc4-kms-v3d,nohdmi is present.
Please collect the following exactly, on the failing Pi 4 + 4.022:
Targeted dmesg slice
sudo dmesg -T | grep -i -e ws\_touchscreen -e dsi -e panel -e drm -e backlight
I2C bus 10 probe for the touch IC
sudo i2cdetect -y 10
sudo i2cdump -y 10 0x45 b 2>/dev/null | head -n 32
DRM and backlight state
ls -l /sys/class/drm
cat /sys/class/drm/card0-DSI-1/status
for f in /sys/class/backlight/\*; do echo \$f; cat \$f/brightness; cat \$f/max\_brightness; cat \$f/bl\_power 2>/dev/null; done
Xorg modes detection
sed -n "1,260p" /var/log/Xorg.0.log
Physical hookup confirmation
Rationale for asking this:
Post these and we will continue.
Hi @nerd, thank you for answering my question that already deleted.
However, Iâd just want to try this bookworm which youâd said before on my previous concern regarding with lcd display issue.
My question is which bookworm version should i tried first? Should i try now the latest bookworm? Does bookworm also supported nvme boot ( install to disk).?
Thank you and regards,
Thanks for answering. Here are the results of your commands:
1 Targeted dmesg slice:
[Sat Sep 20 10:03:00 2025] /soc/cprman@7e101000: Fixed dependency cycle(s) with /soc/dsi@7e700000
[Sat Sep 20 10:03:00 2025] /soc/dsi@7e700000: Fixed dependency cycle(s) with /soc/i2c0mux/i2c@1/panel_disp1@45
[Sat Sep 20 10:03:00 2025] /soc/dsi@7e700000: Fixed dependency cycle(s) with /soc/cprman@7e101000
[Sat Sep 20 10:03:00 2025] /soc/i2c0mux/i2c@1/panel_disp1@45: Fixed dependency cycle(s) with /soc/dsi@7e700000
[Sat Sep 20 10:03:02 2025] /soc/dsi@7e700000: Fixed dependency cycle(s) with /soc/i2c0mux/i2c@1/panel_disp1@45
[Sat Sep 20 10:03:02 2025] /soc/i2c0mux/i2c@1/panel_disp1@45: Fixed dependency cycle(s) with /soc/dsi@7e700000
[Sat Sep 20 10:03:02 2025] v3d fec00000.v3d: [drm] Transparent Hugepage support is recommended for optimal performance on this platform!
[Sat Sep 20 10:03:02 2025] [drm] Initialized v3d 1.0.0 for fec00000.v3d on minor 0
[Sat Sep 20 10:03:02 2025] ws_touchscreen 10-0045: I2C write failed: -5
[Sat Sep 20 10:03:03 2025] ws_touchscreen 10-0045: I2C write failed: -5
[Sat Sep 20 10:03:12 2025] ws_touchscreen 10-0045: I2C write failed: -5
[Sat Sep 20 10:03:13 2025] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
[Sat Sep 20 10:03:13 2025] systemd[1]: modprobe@drm.service: Deactivated successfully.
[Sat Sep 20 10:03:13 2025] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
[Sat Sep 20 10:03:14 2025] ws_touchscreen 10-0045: I2C write failed: -5
[Sat Sep 20 10:03:14 2025] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[Sat Sep 20 10:03:14 2025] vc4-drm gpu: bound fe700000.dsi (ops vc4_dsi_ops [vc4])
[Sat Sep 20 10:03:14 2025] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
[Sat Sep 20 10:03:14 2025] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
[Sat Sep 20 10:03:14 2025] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
[Sat Sep 20 10:03:14 2025] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
[Sat Sep 20 10:03:14 2025] [drm] Initialized vc4 0.0.0 for gpu on minor 1
[Sat Sep 20 10:03:14 2025] vc4-drm gpu: [drm] fb0: vc4drmfb frame buffer device
[Sat Sep 20 10:03:16 2025] ws_touchscreen 10-0045: I2C write failed: -5
[Sat Sep 20 10:03:39 2025] ws_touchscreen 10-0045: I2C write failed: -5
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- UU -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
No results displayed!
If I disable error redirection to null (i.e. âsudo i2cdump -y 10 0x45 b | head -n 32â) the result is:
Error: Could not set address to 0x45: Device or resource busy
total 0
lrwxrwxrwx 1 root root 0 Jan 1 1970 card0 -> ../../devices/platform/v3dbus/fec00000.v3d/drm/card0
lrwxrwxrwx 1 root root 0 Sep 20 11:41 card1 -> ../../devices/platform/gpu/drm/card1
lrwxrwxrwx 1 root root 0 Sep 20 10:10 card1-DSI-1 -> ../../devices/platform/gpu/drm/card1/card1-DSI-1
lrwxrwxrwx 1 root root 0 Sep 20 10:10 card1-Writeback-1 -> ../../devices/platform/gpu/drm/card1/card1-Writeback-1
lrwxrwxrwx 1 root root 0 Jan 1 1970 renderD128 -> ../../devices/platform/v3dbus/fec00000.v3d/drm/renderD128
-r--r--r-- 1 root root 4096 Sep 20 11:42 version
cat: /sys/class/drm/card0-DSI-1/status: No such file or directory
connected
This command fails, donât understand why. âls -l /sys/class/backlightâ gives this:
lrwxrwxrwx 1 root root 0 Sep 20 10:10 10-0045 -> ../../devices/platform/soc/fe205000.i2c/i2c-22/i2c-10/10-0045/backlight/10-0045
If I âcdâ there, I have this:
total 0
-r--r--r-- 1 root root 4096 Sep 20 11:47 actual_brightness
-rw-rw-rw- 1 root root 4096 Sep 20 10:10 bl_power
-rw-rw-rw- 1 root video 4096 Sep 20 11:41 brightness
lrwxrwxrwx 1 root root 0 Sep 20 11:47 device -> ../../../10-0045
-r--r--r-- 1 root root 4096 Sep 20 11:47 display_name
-r--r--r-- 1 root root 4096 Sep 20 10:10 max_brightness
drwxr-xr-x 2 root root 0 Sep 20 11:45 power
-r--r--r-- 1 root root 4096 Sep 20 11:47 scale
lrwxrwxrwx 1 root root 0 Sep 20 10:10 subsystem -> ../../../../../../../../../class/backlight
-r--r--r-- 1 root root 4096 Sep 20 10:10 type
-rw-r--r-- 1 root root 4096 Sep 20 10:10 uevent
And the requested values are:
brigthness -> 255
max_brightness -> 255
bl_power -> 4
[ 40.300]
X.Org X Server 1.21.1.7
[ 40.300] Current Operating System: Linux volumio.casa 6.12.34-v7l+ #1889 SMP Mon Jun 23 11:08:21 BST 2025 armv7l
[ 40.300] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:640x480M@60D numa=fake=1 system_heap.max_order=0 smsc95xx.macaddr=E4:5F:01:EB:43:1E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 splash plymouth.ignore-serial-consoles dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0xF dwc_otg.nak_holdoff=1 quiet console=ttyS0,115200 console=tty1 imgpart=UUID=cc40bcae-8e5b-4465-a1d2-022efc5b5ed0 imgfile=/volumio_current.sqsh bootpart=UUID=CB70-A442 datapart=UUID=c824eb1e-6c2b-4cc1-a030-f182645bbe25 uuidconfig=cmdline.txt pcie_aspm=off pci=pcie_bus_safe rootwait bootdelay=7 logo.nologo vt.global_cursor_default=0 net.ifnames=0 snd-bcm2835.enable_compat_alsa= snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 loglevel=0 nodebug use_kmsg=no
[ 40.300] xorg-server 2:21.1.7-3+rpt3+deb12u10 (https://www.debian.org/support)
[ 40.300] Current version of pixman: 0.44.0
[ 40.300] Before reporting problems, check http://wiki.x.org
[ 40.300] Markers: (--) probed, (**) from config file, (==) default setting,
[ 40.300] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Sep 20 11:41:31 2025
[ 40.315] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 40.315] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 40.328] (==) No Layout section. Using the first Screen section.
[ 40.328] (==) No screen section available. Using defaults.
[ 40.329] (**) |-->Screen "Default Screen Section" (0)
[ 40.329] (**) | |-->Monitor "<default monitor>"
[ 40.329] (==) No monitor specified for screen "Default Screen Section".
[ 40.329] (**) Option "Debug" "dmabuf_capable"
[ 40.329] (==) Automatically adding devices
[ 40.329] (==) Automatically enabling devices
[ 40.329] (==) Automatically adding GPU devices
[ 40.329] (==) Automatically binding GPU devices
[ 40.333] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 40.335] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 40.335] Entry deleted from font path.
[ 40.338] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[ 40.338] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 40.338] (II) The server relies on udev to provide the list of input devices.
[ 40.338] (II) Loader magic: 0x215080
[ 40.338] (II) Module ABI versions:
[ 40.338] X.Org ANSI C Emulation: 0.4
[ 40.338] X.Org Video Driver: 25.2
[ 40.338] X.Org XInput driver : 24.4
[ 40.338] X.Org Server Extension : 10.0
[ 40.343] (--) using VT number 2
[ 40.343] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 40.351] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 40.351] (II) Platform probe for /sys/devices/platform/gpu/drm/card1
[ 40.375] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 40.375] (II) Platform probe for /sys/devices/platform/v3dbus/fec00000.v3d/drm/card0
[ 40.375] (**) OutputClass "vc4" setting /dev/dri/card1 as PrimaryGPU
[ 40.376] (II) LoadModule: "glx"
[ 40.383] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 40.451] (II) Module glx: vendor="X.Org Foundation"
[ 40.451] compiled for 1.21.1.7, module version = 1.0.0
[ 40.451] ABI class: X.Org Server Extension, version 10.0
[ 40.451] (II) Applying OutputClass "vc4" to /dev/dri/card1
[ 40.451] loading driver: modesetting
[ 40.451] (==) Matched modesetting as autoconfigured driver 0
[ 40.451] (==) Matched fbdev as autoconfigured driver 1
[ 40.451] (==) Assigned the driver to the xf86ConfigLayout
[ 40.451] (II) LoadModule: "modesetting"
[ 40.452] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 40.792] (II) Module modesetting: vendor="X.Org Foundation"
[ 40.792] compiled for 1.21.1.7, module version = 1.21.1
[ 40.792] Module class: X.Org Video Driver
[ 40.792] ABI class: X.Org Video Driver, version 25.2
[ 40.792] (II) LoadModule: "fbdev"
[ 40.793] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 40.810] (II) Module fbdev: vendor="X.Org Foundation"
[ 40.810] compiled for 1.21.1.3, module version = 0.5.0
[ 40.810] Module class: X.Org Video Driver
[ 40.810] ABI class: X.Org Video Driver, version 25.2
[ 40.810] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 40.810] (II) FBDEV: driver for framebuffer: fbdev
[ 40.839] (II) modeset(0): using drv /dev/dri/card1
[ 40.839] (WW) Falling back to old probe method for fbdev
[ 40.839] (II) Loading sub module "fbdevhw"
[ 40.839] (II) LoadModule: "fbdevhw"
[ 40.839] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 40.840] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 40.840] compiled for 1.21.1.7, module version = 0.0.2
[ 40.840] ABI class: X.Org Video Driver, version 25.2
[ 40.841] (II) modeset(0): Creating default Display subsection in Screen section
[ 40.841] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 40.841] (II) Applying OutputClass "vc4" options to /dev/dri/card1
[ 40.841] (==) modeset(0): RGB weight 888
[ 40.841] (==) modeset(0): Default visual is TrueColor
[ 40.841] (II) Loading sub module "glamoregl"
[ 40.841] (II) LoadModule: "glamoregl"
[ 40.841] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 40.905] (II) Module glamoregl: vendor="X.Org Foundation"
[ 40.905] compiled for 1.21.1.7, module version = 1.0.1
[ 40.905] ABI class: X.Org ANSI C Emulation, version 0.4
[ 41.221] (II) modeset(0): glamor X acceleration enabled on V3D 4.2.14.0
[ 41.221] (II) modeset(0): glamor initialized
[ 41.221] (==) modeset(0): VariableRefresh: disabled
[ 41.221] (==) modeset(0): AsyncFlipSecondaries: disabled
[ 41.222] (II) modeset(0): Output DSI-1 using monitor section DSI-1
[ 41.222] (**) modeset(0): Option "Rotate" "normal"
[ 41.295] (II) modeset(0): EDID for output DSI-1
[ 41.298] (II) modeset(0): Printing probed modes for output DSI-1
[ 41.298] (II) modeset(0): Modeline "320x1480"x60.2 50.00 320 380 440 500 1480 1540 1600 1660 (100.0 kHz eP)
[ 41.298] (II) modeset(0): Output DSI-1 connected
[ 41.298] (II) modeset(0): Using exact sizes for initial modes
[ 41.298] (II) modeset(0): Output DSI-1 using initial mode 320x1480 +0+0
[ 41.298] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 41.298] (==) modeset(0): DPI set to (96, 96)
[ 41.298] (II) Loading sub module "fb"
[ 41.298] (II) LoadModule: "fb"
[ 41.298] (II) Module "fb" already built-in
[ 41.298] (II) UnloadModule: "fbdev"
[ 41.298] (II) Unloading fbdev
[ 41.298] (II) UnloadSubModule: "fbdevhw"
[ 41.298] (II) Unloading fbdevhw
[ 41.794] (==) modeset(0): Backing store enabled
[ 41.794] (==) modeset(0): Silken mouse enabled
[ 41.818] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 41.819] (==) modeset(0): DPMS enabled
[ 41.819] (WW) modeset(0): Option "PrimaryGPU" is not used
[ 41.819] (II) modeset(0): [DRI2] Setup complete
[ 41.819] (II) modeset(0): [DRI2] DRI driver: vc4
[ 41.819] (II) modeset(0): [DRI2] VDPAU driver: vc4
[ 41.819] (II) Initializing extension Generic Event Extension
[ 41.819] (II) Initializing extension SHAPE
[ 41.820] (II) Initializing extension MIT-SHM
[ 41.820] (II) Initializing extension XInputExtension
[ 41.825] (II) Initializing extension XTEST
[ 41.825] (II) Initializing extension BIG-REQUESTS
[ 41.826] (II) Initializing extension SYNC
[ 41.827] (II) Initializing extension XKEYBOARD
[ 41.827] (II) Initializing extension XC-MISC
[ 41.828] (II) Initializing extension SECURITY
[ 41.828] (II) Initializing extension XFIXES
[ 41.829] (II) Initializing extension RENDER
[ 41.829] (II) Initializing extension RANDR
[ 41.847] (II) Initializing extension COMPOSITE
[ 41.848] (II) Initializing extension DAMAGE
[ 41.848] (II) Initializing extension MIT-SCREEN-SAVER
[ 41.849] (II) Initializing extension DOUBLE-BUFFER
[ 41.849] (II) Initializing extension RECORD
[ 41.858] (II) Initializing extension DPMS
[ 41.859] (II) Initializing extension Present
[ 41.859] (II) Initializing extension DRI3
[ 41.860] (II) Initializing extension X-Resource
[ 41.861] (II) Initializing extension XVideo
[ 41.861] (II) Initializing extension XVideo-MotionCompensation
[ 41.861] (II) Initializing extension SELinux
[ 41.861] (II) SELinux: Disabled on system
[ 41.861] (II) Initializing extension GLX
[ 42.101] (II) AIGLX: Loaded and initialized vc4
[ 42.101] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 42.101] (II) Initializing extension XFree86-VidModeExtension
[ 42.102] (II) Initializing extension XFree86-DGA
[ 42.103] (II) Initializing extension XFree86-DRI
[ 42.103] (II) Initializing extension DRI2
[ 42.122] (II) modeset(0): Damage tracking initialized
[ 42.122] (II) modeset(0): Setting screen physical size to 84 x 391
[ 52.748] (II) modeset(0): Disabling kernel dirty updates, not required.
Thanks again for your support. Regards.
Hey @aluisperezh,
Next checks:
Please run these exact commands and paste outputs:
If step 1 brings bl_power to 0 and actual_brightness becomes nonzero, we will know the fix is to ensure the backlight is not forced off by the touch driver during boot. If unblank fails or flips back to 4, the ws_touchscreen errors are likely asserting a shutdown path and we will try a minimal overlay parameter or driver blacklist next to let the panel light while we sort touch.
Good timing. Since you already tested everything possible on Volumio 3 (Buster), the next logical step is to move to the Volumio 4.xxx Bookworm Beta branch. Thatâs where the Raspberry Pi 5 is fully supported and where the video=HDMI-A-1:400x1280M@60,rotate=270 syntax works as intended.
So short answer:
Also, please spend some time on reading opening posts, which already include this information an more.
Hi again @nerd.
First thing I found is that /sys/class/backlight/10-0045/bl_power is 0 when the system boots. A few seconds after the âBOOT COMPLETEDâ message, the " ws_touchscreen 10-0045: I2C write failed: -5" is displayed again (3x) in the logs and then bl_power changes to 4. The âws_touchscreenâŚâ message is not shown again in the logs. I waited until bl_power changed to 4 before executing your commands.
volumio@volumio:~$ sudo sh -c 'echo 0 > /sys/class/backlight/10-0045/bl_power'
volumio@volumio:~$ cat /sys/class/backlight/10-0045/actual_brightness
255
volumio@volumio:~$ cat /sys/class/backlight/10-0045/bl_power
0
volumio@volumio:~$ cat /sys/class/backlight/10-0045/max_brightness
255
volumio@volumio:~$ cat /sys/class/backlight/10-0045/brightness
255
volumio@volumio:~$ sudo sh -c 'echo 255 > /sys/class/backlight/10-0045/brightness'
255
volumio@volumio:~$ sudo dmesg -T | grep -i -e backlight -e pwm -e regulator -e ws_touchscreen -e panel
[Sat Sep 20 18:47:48 2025] /soc/dsi@7e700000: Fixed dependency cycle(s) with /soc/i2c0mux/i2c@1/panel_disp1@45
[Sat Sep 20 18:47:48 2025] /soc/i2c0mux/i2c@1/panel_disp1@45: Fixed dependency cycle(s) with /soc/dsi@7e700000
[Sat Sep 20 18:47:49 2025] pci_bus 0000:01: supply vpcie3v3 not found, using dummy regulator
[Sat Sep 20 18:47:49 2025] pci_bus 0000:01: supply vpcie3v3aux not found, using dummy regulator
[Sat Sep 20 18:47:49 2025] pci_bus 0000:01: supply vpcie12v not found, using dummy regulator
[Sat Sep 20 18:47:50 2025] /soc/dsi@7e700000: Fixed dependency cycle(s) with /soc/i2c0mux/i2c@1/panel_disp1@45
[Sat Sep 20 18:47:50 2025] /soc/i2c0mux/i2c@1/panel_disp1@45: Fixed dependency cycle(s) with /soc/dsi@7e700000
[Sat Sep 20 18:47:50 2025] ws_touchscreen 10-0045: I2C write failed: -5
[Sat Sep 20 18:47:51 2025] ws_touchscreen 10-0045: I2C write failed: -5
[Sat Sep 20 18:48:00 2025] ws_touchscreen 10-0045: I2C write failed: -5
[Sat Sep 20 18:48:02 2025] ws_touchscreen 10-0045: I2C write failed: -5
[Sat Sep 20 18:48:02 2025] Goodix-TS 10-0014: supply AVDD28 not found, using dummy regulator
[Sat Sep 20 18:48:02 2025] Goodix-TS 10-0014: supply VDDIO not found, using dummy regulator
[Sat Sep 20 18:48:02 2025] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[Sat Sep 20 18:48:02 2025] hci_uart_bcm serial0-0: supply vbat not found, using dummy regulator
[Sat Sep 20 18:48:02 2025] hci_uart_bcm serial0-0: supply vddio not found, using dummy regulator
[Sat Sep 20 18:48:04 2025] ws_touchscreen 10-0045: I2C write failed: -5
[Sat Sep 20 18:48:26 2025] ws_touchscreen 10-0045: I2C write failed: -5
[Sat Sep 20 18:50:30 2025] ws_touchscreen 10-0045: I2C write failed: -5
[Sat Sep 20 19:03:31 2025] ws_touchscreen 10-0045: I2C write failed: -5
[Sat Sep 20 19:05:50 2025] ws_touchscreen 10-0045: I2C write failed: -5
volumio@volumio:~$ sudo dmesg -T | grep -i ws_touchscreen | tail -n 50
volumio@volumio:~$ lsmod | grep ws_touchscreen
volumio@volumio:~$
volumio@volumio:~$ cat /sys/class/drm/card1-DSI-1/enabled
enabled
volumio@volumio:~$ cat /sys/class/drm/card1/uevent
MAJOR=226
MINOR=1
DEVNAME=dri/card1
DEVTYPE=drm_minor
After all these tests, bl_power is still 0, and nothing has appeared in the screen nor backlight has turned on.
Best regards.
Hey @aluisperezh,
Based on everything you verified, you have enough to take this up with Waveshare. Please open a ticket with their support and include the details from our tests so they can reproduce and advise a firmware or driver fix.
Given that another identical screen works with the same Pi 4 and the non-working screen does work on Pi 5, this points to a device- or firmware-specific init quirk exposed only on Pi 4 with this kernel/userspace. We believe Waveshare is best positioned to advise the correct overlay or driver changes.
Thank you again for your support. Iâll try to find out something with Waveshare.
Best regards.
Hi everyone,
OTA update from 4.022 to 4.023 â OK
Rpi 4, boot on SD with official Touch Display 2 and allo DigiOne Signature
Plugins : Touch Display // Radio Paradise // SqueezeLite MC
Logs if useful for developers
Regards
Benoit
OTA from 4.022 to 4.023
Pi4B, SD boot, Topping D10S USB DAC
Tested and working:
Tidal and Tidal Connect playback
Playing local files
Web Radio
Log http://logs.volumio.org/volumio/kEJ2Fiw.html
Super stable for me the last few versions.
Seamless OTA Update: 4.022 â 4.023
Just completed the over-the-air update from 4.022 to 4.023âflawless execution.
Running on Pi5 with NVME boot and Cambridge Audio DacMagic 200M via USB. Everything working perfectly.
Today marks a truly significant milestone in the Volumio journey:
The Volumio Bookworm Beta is officially entering its pre-release phase.
This is the final stretch. The system has reached feature completeness and is now on the formal path toward release readiness.
This is not just a version bump. This is the result of months of coordinated work across:
None of this would have been possible without the incredible support and dedication of our community.
From developers submitting patches and logs, to testers hammering early builds, to those reporting obscure edge cases and helping us track down hardware-specific regressions - you have made this possible.
To everyone who contributed, gave feedback, tested builds, rebuilt packages, or simply stayed patient while the system matured: Thank you.
Now, as we move into final qualification:
The qualifying beta is now under formal evaluation for stable release.
Letâs keep the momentum going.
Fingers crossed - weâre almost there.
Hi @nerd, thank you for always helping me with my concerns. Finally, made it worked!
Does this mean that Volumio Primo V1 (Thinkerboard based) will be upgradeable to this new version?
