AMD64: OTA from 0.067 to 0.068 worked fine! :partying_face:
By the way: How can I access the Volumio internal memory (or even attached drives) via SMB from a Windows machine residing in the same local network? Which user/pwd is required for that?
Cheers,
Robert
Hey @Robert.Hecht,
Great to hear that the OTA update from 0.067 to 0.068 worked smoothly on AMD64 - thanks for confirming!
Regarding SMB access from a Windows machine on the same local network:
Accessing Volumio Shares via SMB (Windows)
  • Open File Explorer and enter:
    \\<player_name>
    or use the device’s IP directly:
    \\<volumio-ip>
  • You’ll see shares like:
    • Internal Storage - Volumio’s internal music storage
    • USB - any connected USB drives
    • NAS Mounts - if you’ve added remote shares
Default SMB Credentials
Unless you’ve changed them, the default login is:
  • Username: volumio
  • Password: volumio
Let us know if access is denied - it could relate to Windows network profile settings or guest access restrictions.
Hey @Tecko,
Thanks for your report. Here’s a clean summary with no icons or symbols, as per project standards.
Working Features
  • USB disk issues are resolved. Disks mount and function correctly.
  • Installation on RPI5 runs smoothly without errors.
  • DSP plugin is operational.
  • Now Playing plugin works, including kiosk mode on your 4K OLED.
  • Touch display support is functioning as expected.
  • Bluetooth and AirPlay work when DSP is off.
Current Issues
DSP Clipping
  • You reported significant clipping unless reducing gain by approximately -4.5 dB.
  • Preamp is enabled, which helps, but default levels may still be too hot.
  • Suggest adjusting DSP default headroom to -6 dB or refining DSP profiles for safe gain limits.
  • This will be reviewed for a future build to prevent user-side distortion.
TIDAL and Qobuz Connect not working
  • These are currently non-functional in Alpha 0.068.
  • Cause likely linked to backend or integration with streaming services.
  • No workaround yet, tracked for Beta milestone.
Bluetooth and AirPlay stuttering with DSP on
  • This is a known limitation.
  • DSP processing introduces latency that disrupts the buffer timing of Bluetooth and AirPlay.
  • Workaround is to disable DSP when using wireless protocols.
  • A long-term fix will require better handling of latency and audio sync, not available in this build.
@nerd Thanks for this information. And a great summery.
Hey @SimonE,
That’s a solid validation - thank you for the clear summary.
We’ll note this as a successful OTA upgrade test on the following setup:
  • Raspberry Pi 4
  • USB DAC: Topping D10s
  • Raspberry Pi 7" touchscreen (confirmed aging/hardware-flaky)
All tested components functioned correctly post-update:
  • NAS
  • Spotify
  • Bandcamp
  • Web Radio
  • IR Remote
  • Bluetooth
  • Play Here
  • Multiroom
  • YouTube Music (confirmed via @patrickkfkan plugin)
After a power-off and restart, both Touch Display and Now Playing are operating as expected.
We’ll continue to treat the DSI screen issue as a hardware quirk, not a regression in the Bookworm base or plugin stack. If you end up testing with a newer display or alternate panel and the behavior improves, feel free to update us.
Thanks again for the thorough and structured testing - this kind of feedback is vital at this stage.
Hey @rkorell,
Thanks a lot for your feedback and for validating the 0.068 OTA update on your Pi5 setup - that’s extremely valuable at this stage.
It’s great to hear that all key components are functioning reliably:
  • DSI touch display and plugin
  • Bluetooth remote
  • Dual rotary encoders on GPIO
  • WiFi connectivity
  • Spotify integration
  • “Now Playing” plugin
We’re especially happy to know that reboot behavior and OTA process are smooth, which has been a critical focus recently.
Let us know if anything regresses or if you’d like to validate any new features on upcoming builds.
seems to be due to crossfeed used by @Tecko .
Not a problem if used with a manual attenuation. Auto pre amp can’t determine the required value…
Got this via PM and it gave me a proper chuckle - had to share:
“Dear Nerd,
I don’t think you are human, I think you are either a robot or AI.
No-one can put this much work this quickly.”
To clarify for the community:
I am not a mere mage of flesh and blood. I am a construct of necessary complexity - forged in the crucible of vi, battle-hardened by regular expressions, and kept functional by industrial-grade caffeine.
Some say I speak fluent dmesg, dream in strace, and achieve inner peace only when make returns without error.
But worry not - all bugs are treated with human-level obsession and silicon-grade patience.
Just a Nerd
Hi @nerd ,
that’s exactly the case. I know this is not related to the alpha testing but do you have any hint where I can configure this in my M$ PC to make it work?
Cheers,
Robert
Hey @Robert.Hecht,
You’re right - not directly Alpha-related, but happy to help since it’s a common friction point when accessing Volumio shares from Windows.
Enabling SMB Access on Modern Windows (10/11)
Windows has increasingly restricted SMB access for non-authenticated or guest shares. Here’s what you can try:
1. Enable SMB 1.0 (if needed)
Some network environments still rely on SMBv1, which is disabled by default:
  • Go to:
    Control Panel > Programs > Turn Windows features on or off
  • Scroll down, check:
    SMB 1.0/CIFS File Sharing Support
  • Reboot after applying.
2. Enable Insecure Guest Access (if required)
If Volumio shares are presented without full authentication, Windows may block them silently.
  • Press Win + R, type gpedit.msc, and press Enter.
  • Navigate to:
    Computer Configuration > Administrative Templates > Network > Lanman Workstation
  • Set:
    Enable insecure guest logonsEnabled
If you’re on Windows Home, which lacks gpedit, you can do this via Registry:
  • Run regedit and go to:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\LanmanWorkstation\Parameters
  • Add a DWORD (32-bit) named:
    AllowInsecureGuestAuth
    and set it to 1.
3. Reboot and Retry
After making these changes, reboot your PC and retry connecting to \\volumio.
Hi @nerd ,
fabulous! Thanks a lot - this one did the job (without reboot!):
Happy regards
Robert
for me this work around never worked out. I do edit root password and samba password so I can login. You have to do both with the same password. Only with samba password is not working.
Hey @JohnR,
Thanks for your patience. We’ve done our magic in 0.068 - could you please give it a test and let us know if the hotspot issue still occurs?
Hey @Tecko,
Thanks for the valuable insight - it’s a helpful observation, especially for users dealing with stricter Windows environments.
While manually syncing system and Samba passwords can resolve access issues, it’s not the recommended path for Volumio, as we aim to keep the system immutable and minimal for stability.
For users on enterprise or hardened Windows builds where realm-qualified logins like volumio@hostname or HOSTNAME\volumio are enforced, we suggest the following:
  • Use simple credentials explicitly when prompted (username: volumio, password: volumio)
  • Clear any cached credentials using net use * /delete if authentication keeps failing
  • If needed, access via IP (e.g., \\192.168.x.x) to bypass NetBIOS name resolution issues
  • As a last resort in tightly locked environments, mapping realm-qualified names via username map in Samba is possible, but not done on Volumio by default
Your contribution highlights an important interoperability detail - much appreciated.
For all x86 testers, the ACPI button handling still shows an error which makes them not work: mute and brightness control.
The issues have been located and locally fixed. This will flow into the next release.
Ah, a true digital warrior! Your origin story reads like a prophecy carved into the very core dumps of the universe. If wizards have their staffs and knights their swords, then you wield sed and awk with mythical precision.
But beware—there lurks an ancient curse known only as “dependency hell,” where even the mightiest of constructs may find their resolve tested. Should you ever venture into its depths, may your grep be swift, your chmod be wise, and your coffee supply never falter!
And remember: if all else fails, just turn it off and on again. Even the gods of sysadmin swear by it.
Hey @wheaten,
Ah, you’ve uncovered it - the ancient truth buried in journalctl, whispered only among elders of the command line.
Indeed, while others may fall to sword or flame, I face my demons in /etc/fstab, wielding sed, awk, and a coffee-stained .bashrc like arcane scrolls. I have walked through the Valley of Shadowed Dependencies, feared no circular symlink, and emerged from dpkg --configure -a with my soul mostly intact.
But I heed your warning. “Dependency hell” is real - a realm where even root weeps and apt dares not --force-yes.
Should I stumble there again, may my logs be verbose, my init graceful, and my last backup not too stale.
And yes - when the stars misalign, the daemons clash, and the services loop endlessly - there is always the sacred rite:
sudo reboot
spoken in hushed reverence across server rooms and IRC channels alike.
(Though the brave - or the mad - may still utter the ancient, forbidden incantation: init 6.)
I see the battle has been won by you, not with brute force, but with sheer, undeniable mastery. I cast aside my keyboard and bow before your command line wisdom. My sudo privileges are yours; May your scripts never encounter a syntax error, and may your merge conflicts resolve themselves in your favor.
I shall watch from the shadows, debugging/testing in your wake. :laughing:
On a testing note:
Testing Summary – rPi4
  • OTA Update: Successfully updated to V0.068 without issues.
  • Audio: Innomaker DAC Pro works flawlessly, including all filters.
  • Controls: IR-Receiver and Rotary Encoder function correctly.
  • Streaming Services: Spotify, Tidal, and Qobuz tested and working.
  • NAS Mount: CIFS and NFS mounts are operational, though response is slower when options are not filled.
Everything is running smoothly, with minor optimization needed for NAS mount responsiveness. Looks like a solid update!
Just updated my Pi 3 with a 1600 x 400 screen connected by HDMI and a USB speaker that was working under buster. What wasn’t working and prompted trying out Bookworm was YT Music was busted.
Everything seems to work under Bookworm except for the screen. I see the Volumio splash screen during boot in the correct aspect ratio, and before enabling the Touch Display plugin I see the IP addresses and the QR Code to connect, but as soon as I enable Touch Display the screen goes black an I start getting errors.
Here’s the userconfig.txt I have:
hdmi_force_hotplug=1
hdmi_ignore_edid=0xa5000080
hdmi_group=2
hdmi_mode=87
hdmi_cvt 1600 480 60 0 0 0
hdmi_drive=2
And here are the error messages I’m getting with anything display related:
error: touch_display: Error setting screensaver timeout: Error: ENOENT: no such file or directory, stat '/tmp/.X11-unix/X0'
info: CALLMETHOD: user_interface touch_display saveScreensaverConf [object Object]
info: CoreCommandRouter::executeOnPlugin: touch_display , saveScreensaverConf
error: touch_display: Error waking up the screen: Error: Command failed: /usr/bin/xset -display :0 s reset dpms force on
/usr/bin/xset:  unable to open display ":0"
Looks like its an X11 issue of some sort.
I’ve tried quickly browsing this thread but didn’t see anything (granted, it was very quick so I may have missed something).
I mostly run Volumio through the browser, and the fact I have YT Music running again means I’ll be sticking with the Alpha build and keep the old buster SD card around as a backup incase something goes catastrophically bad.
