Hi All,
Please if somebody can help as I am using a 4K TV but the Peppy Screen is not covering the entire screen and even if I am selecting any resolution from the options, I end up having the same as shown in the image
https://i.imgur.com/rUxtlDN.jpeg
Please advise if do I need to do a fresh installation or if I need to make some changes in the existing files/folder.
@ rajiv.kumar1984
Try to do this:
  1. Connect via FTP
  2. go to - boot / userconfig.txt
    3.Add:
    hdmi_group = 2
    hdmi_mode = 87
    hdmi_cvt 1920 1080 60 3 0 0 0
    hdmi_drive = 2
I recently updated to 3.233 but with PeppyMeter plugin, I had to start from scratch. I couldn’t update on the fly. Anyway, it’s not a big problem because I just follow the steps on my note and have it up in a short time.
Next time disable the non official plugin first, then perform the OTA then enable it again. This is how I did the OTA update with success.
Thanks for the tip. Yes, it did work!
A few of my skins
Wow that looks so nice.
Is there any planned project to display VU meters for ROON (i.e. roon bridge on raspberry pi 4 running volumio)?
They look great, are you able to share?
No problem, but I only have a resolution of 1920x1080.
Oh, I need 1024x600… thanks for offering to share, much appreciated.
Kindly please share for 1920 x1080.
custom_4 (1920x1080)_overwrite.zip (7.0 MB)
Replace extension from zip to rar
Currently I have created 4 lay-outs for screens with a resolution of 1280x400:
black-blue-square:
black-blue:
black-white-yellow:
black-panel:
black-white:
black-paris:
vintage:
vintage-2:
Next skin (1920x1080)
Assume it’s not a straight forward task to get these to work at 1024x600?
to whom is that question?
In relation to Gelo5 skins, but open to anyone that can help.
You can download it and modify the meter.txt, to position everything. Without the screen it’s hard to do.
@ bungie240I don’t have a 1024x600 LCD. I did it by hand without a monitor. Give it a try.1024x600.zip (486.9 KB)
Unzip, copy to /data/plugins/miscellanea/peppy_screensaver/peppymeter/custom_2 (1024x600)
Overwrite meter.txt and copy new 3xpng files + 1x jpg
And new skin8
