Thanks, I’ll give this a try.
Hi, it works, thanks you very much for taking the time to do this - Would be useful to know how you did it as I’d like to do the other ones you created. :partying_face:
As @Wheaten wrote, download this file (set for 1920x1080), scale to 1024x600, modify meter.txt.
One more skin I can make for you, but which one? (Remember I don’t have a 1024x600 LCD and I do it “without seeing the effect”
Thanks for offering to do 1 more, the McIntosh would be great. Excellent result on the first attempt without the screen on 1024x600. :+1:
I will have a play with the others… :crossed_fingers:
Instructions are on github.
Try: 1024x600.zip (1.2 MB)
All Skin 1920x1080
1920x1080 Gelo5_part1.zip (7.7 MB)
1920x1080 Gelo5_Part2.zip (4.6 MB)
Would you pls add this also for 1920x1080 in a zip files and needles.
See above. Take photos if they work. Do you have any idea for a skin?
Thanks,
I like very much the accuphase and mcintosh ones.
casdeck (1280x400):
NAD (1280x400):
@Wheaten SUPER!!!
@bungie240
I improved the skin a bit (from the photo).
Now try to install 3 skins 1024x600:1024x600_3skin.zip (2.0 MB)
nad-d3045 (1280x400) (not the best but the last)
nad-6325:
black:
Now I am done :thinking:
Hi Gelo5, this look awesome! My screen resolution is 1280x800 which I took out from my old Dell laptop. Is there any way that you can do this size for me or guide me how to do it?
Thanks.
Andy
What do you think about this one :frowning:
It will be hard to mount in a case, I see that does not have any scre holes…
RON 191.18 35%OFF | raspberry pi Aida 64 display 8.8 inch 1920x480 IPS LCD screen with 60Hz Driver board original brand new
Try (Remember I don’t have a 1280x800 LCD and I do it “without seeing the effect”)
1280x800.zip (758.9 KB)\
I think the needle may be too short. Here’s the fix1280x800_correct.zip (2.8 KB)
Hi Gelo5 - Thanks again for doing these, for me they seem to work great. :+1:
you’re welcome. 🙋
Thank god for Bison kit…
However I think it would annoy me in the long run, that the right bezel is wider than the left.
Thanks Gelo5, here is what it looks like on my screen.
If it’s not too much to ask, can I have the other two (the Accuphase and the one with two big vu meters) as well on 1280x800?
Thanks again.
Andy
