Hi, it would be possible to have a “guide” skill, that is, with notes inside the meter file that clarify how to replace photos and coordinates to create skins independently.
Thanks bye
Hi I’m trying to download the already made skins starting from its creator Gelo5, resolution 1920x1080, in the 15 zip files that appear by clicking on the name gelo5 the meters file of the akay skin is missing.
Did I overlook something?
Thanks bye
last zip (11,9 KB)
the akay skin’s in the graphic files: meters file is missing.
Thanks bye
Added
Project with PeppyMeter Screensaver Plugin for VOLUMIO v2.9xx and 3.0xx buster - #738 by Gelo5?
Please Help!
I installed Volumio as a new system as described.
after istallation
Step 1 touch display installed
Step 2 reboot
display works
step 3 copy peppy_scrensaver to Volumio\peppy_scrensaver
step 4 connect putty to Volumio
step 5 change to the directory peppy_screensaver
Step 4 Install with Volumio plugin install
no error messages so far
system reboot
Start playing music
Now the error!
What can I do?
Thanks, but now I just have a blank display
What’s your setup? What DAC are you using or just usb? RPI, TB, x86?
After turning off Peppymeter everything works?
Do you have the correct resolution set?
copy to home/VOLUMIO?
What’s your setup?
The setup is the same
I use a USB audio sound card on RPI 4
Yes
I have copy to home/VOLUMIO !
after installing peppymeter the screen is blank
where do i set the resolution?
I have that too
What is your monitor resolution?
thank you for your help!!
now everything works very well
Kudos to the developer and the many tips here
Is it possible a small update to 1024x600? i kindly ask…
When I have free time. It takes a long time.Which ones are you interested in?
Only 1920x1080 can be converted.
