hard to debug this, as peppy won’t generate any logging.
  • You just took one of the standard templates and that is giving these errors?
  • Is the sound also interrupted?
Yes, it is standart templates. Sound is absolutely clear, without any interruptions.
Sorry have no idea.
I have almost the same plugins loaded, but no issues with peppy.
maybe someone else has a clue?
Try with the settings
Or 5, 4, 3…
does this display work well with peppymeter?
I think it is a waveshare screen.
am planning to purchase one.
https://www.raspberrystore.nl/PrestaShop/nl/beeldschermen/429-79-inch-lcd-beeldscherm-614961956704.html
yes, same as mine.
thanks and already ordered.
yes
All the same but lazier.
I guess faster? The lower the value, the faster.
Hmmm, seems not to work in combination with Hifiberry.
If peppymeter is installed Hifiberry doesn’t initialize any more.
After deinstalltion of peppymeter works fine.
(I use Raspberry PI 3B+)
Does anyone have it running with Hifiberry.
Would be great to get a hint.
It works, it works. Change settings in Peppymeter.
Could show your settings?
And already built in and works we’ll.
only need to cut the front plate to size and repaint it.
buttons on the right are also moved so that they line up.
New layout.
Old layout.
Sorry for my delayed answer.
After changing my settings regarding yours, Hifiberry works - thanx a lot.
But the Peppymeter Screensaver doesn’t start.
I set the screensaver timeout in touch display to 100 and No screensaver during playing to ON like it is suggested in PeppyMeter. The PeppyMeter settings I did like yours. (My HDMI screen has the same resultion as yours)
What tricky setting I have to adjust for that to make it working?
Reinstall Peppymeter as a plugin (post 7). Set the desired monitor resolution. It has to work.
P.S. I don’t have Hifiberry, I have Pi2aes
I deinstalled Peppymeter, rebooted raspi, installed Peppymeter again (Done! Plugin Successfully Installed), activated the plugin Peppymeter, rebooted raspi again.
Peppymeter doesn’t start.
Played with differen resultions of Peppymeter - no success.
My Peppymeter directory is /home/volumio/peppy_screensaver but I guess this is right, cause the plugin is shown and the different screens are configurable.
… but it doesn’t start.
Not! why don’t you read where to upload skins??? Click on my Avatar, see the skins and the folder where to upload them.
Or run the original
Sometimes you need to install the touchscreen plug-in (don’t know why)
Ahhh, I have to copy the zip to /home/volumio/Install_peppy.
Okay I will change that after deinstalling Peppymeter.
I’ll also reinstall the touchscreen plugin, if the renaming not works
