Just to clarify: I often browse the forum on my smartphone. Some likes are the result of “scrolling” the page. They are not always correct.
So all the likes I got are actually scrolling mistakes… that hurts :disappointed:
Yours from me are OK :slight_smile: :crazy_face:
Many thanks Gelo5 - Much appreciated!
Would be grate on native volumio plugin.
If not us someone will one-day.
Thank you.
All skins updated. Click on my Avatar, you will see a link to skins.
That’s over 180 skins for different resolutions.
Time to leave this thread.
If there are any bugs - let me know.
Please, can you help on this “COVER FLOW” CSS3 will be one of a kind and will lost long for a generation.
Thanks much!
Hi Gelo5,
would it be possible to make your AdvenX220 available in 1480 x 320? The part looks terrific in 1280x400, certainly one of the most beautiful skins so far. I’m building a new case next week and would be grateful for this skin.
@Joersch
Project with PeppyMeter Screensaver Plugin for VOLUMIO v2.9xx and 3.0xx buster - #738 by Gelo5?
Awesome, thanks Gelo5. Here is a picture of your X220 on my current display
Thanks to Gelo5
@Gelo5 small problem screen remains blank…Custom_1 (800x480)
the file Gelo5_Triplett is not present in the folder for Custom_1 (800x480) in the meter.txt file Triplett is present.
Schermafbeelding 2022-10-27 om 23.54.36
Schermafbeelding 2022-10-27 om 23.54.05
Fixed - added graphics
Oeps is that all of the scripting :crazy_face:
The grafix takes longer to make lol
And creating a nice zip lol
Thanks :+1:
dear gelo my screen is 1280*800 and the hands are up how can i get it down. which code should i change
can you help me
[gold]
meter.type = circular
channels = 2
ui.refresh.period = 0.033
steps.per.degree = 4
start.angle = 44
stop.angle = -44
distance = 170
left.origin.x = 353
left.origin.y = 305
right.origin.x = 977
right.origin.y = 305
meter.x = 0
meter.y = 204
— volumio optional entries -------
config.extend = True
albumart.pos = 39,561
albumart.dimension = 213,213
playinfo.title.pos = 308,713,bold
playinfo.artist.pos = 308,744,light
playinfo.album.pos = 308,915,regular
playinfo.center = True
playinfo.maxwidth = 577
playinfo.type.pos = 617,260
playinfo.type.color = 94,91,80
playinfo.type.dimension = 45,45
playinfo.samplerate.pos = 351,305,regular
time.remaining.pos = 564,370
time.remaining.color = 94,91,80
font.size.digi = 45
font.size.light = 23
font.size.regular = 24
font.size.bold = 24
font.color = 220,220,220
The entire entry is correct. Do other skins behave the same?
You have here and re-upload graphics (overwrite)
Gold.zip (465.5 KB)
The following entry is responsible for this situation:
meter.y = 204
Hello , vumeters are in different places in all pictures, I have adjusted 5 of them with meter.y and mtere.x, thank you very much for your valuable help.
Thanks @ Gelo5 for the 1280 x 400 screensavers :pray:
I have found a way to deactivate or activate a plugin. With a command in ssh, I rename the respective plugin folder. You can include this in a script. I built a shortcut for my iPhone that turns the PeppyMeter plugin off or on. So that no errors occur, I have written another start script that always activates the plugin at system startup.
Best regards
Hi that’s brilliant! :+1: Can you share how this can be done?
