Change the graphic, add a new item in meters.txt
When I have time - I will do the subtitles. Now you only have without the cover and without the “WIDE RANGE SCALE-PEAK POWER METER”. Artifacts removed (I think?)
1280x400_G700_2.zip (224.2 KB)
I love the changes. I was debating on adding the cover art or not. I did another one in black. I may do cover art on that one.
Do whatever you think. I don’t use this resolution, but others will be happy to use it. 🙋
There is no sense in the cover. It is so small that it looks like a colored spot. The whole point is in the purity of the Technics.
- arrows
- bit depth
- sample rate
- file type
- title-info line running only to the left around
- black version
- warm or sepia version (why? because the screen backlight is too cold ~6500K)
All of we need ))))))
What do you mean?
Seriously, when moving left-right, left-right, left-right, an unpleasant parallax effect is created.
Right here, on this skin - there’s only 360px space. How would you like to fit a long text? The only option is to make the font smaller (and it’s still small). There is plenty of space for text at the top of the skin.
You can not have everything.
Is it possible to rotate text only to the left, in a circle ???
it should be possible that is how a normal marquee works
if you don’t want the movement just create a bigger box so it doesn’t have to move
Not necessarily, in this case the meters will be disturbing. They will cause artifacts🤪 max.360px
Various things can be done🍻
the vinyl player is really cool
Oke i don’t know the limits of peppy it should be able to do full screen.
If it’s just JS running the show
but peppy can have it’s limits.
360px is very small if you run a 4k monitor lol
No no. You did not understand. We’re talking about a specific Technics skin (1280x400).
Oke i get it
did the fix work?, there is still no sound
It doesn´t work well for me. My system hangs after playing some songs…
Hi guys,
I’m back with another YouTube video on PeppyMeter screensaver in 1280 x 400 touchscreen format as promised.
Hope you will enjoy.
Very nicely. In the g700 skin, replace the image of fgr.
Project with PeppyMeter Screensaver Plugin for VOLUMIO v2.9xx and 3.0xx buster - #738 by Gelo5?
ONLY fgr (1280g700m2-fgr.png)
