I must say this, what am awesome album you’re listening while peppymetering :slight_smile: :ok_hand:
Can you help me. The system I use is windows x86 and spotify does not move the hands. I don’t have the /etc/spopd.conf file.
Hands are moving in parts such as youtube, usb music
Any idea what would cause these strange artifacts with my meters?
if anyone is interested in this su-g700 inspired screen for the waveshare 7.9
g700m2.zip (252.8 KB)
This is my size ). Thank you.
Thank you so much! It worked!!
Hello
Is it possible to create the g700m2 for a 7" display (1024x600)
Many greetings
Of course you can. Only who wants to do it?
You can do it yourself:Photoshop + Wiki and go.
You can also try others that are already ready. Click on my avatar😈
can you send me these two files i can’t find the files
hello everyone…what i wanted to ask is it normal that i can’t find a 1280x400 folder, i wanted to make some changes but can’t find a corresponding folder…can someone please help me out? i wanted to edit the blue one in 1280x400 a little…can’t find a background image of it in the folders
i have tried a little bit, and inserted all 1280x400 screens here from the thread into all folders, and also inserted the meters.txt…nevertheless no new skins are displayed in the selection menu…
Where did I put them? To what folder?
1280x400 = Wide
thanks for your answer 2aCD I do not have such a file where can i find this file
Hi Gelo :slight_smile: … thanks for the help…i have created this folder with wide…have packed all screens, in all folders, and also the masters with all entries, but no matter which mode i select, no screen appears, except the ones that were included with the install
Unbenannt
Not this folder!
/data/plugins/miscellanea/peppy_screensaver/peppymeter/wide.
ah okaaayy, i’ll try that…thanks a lot :wink:
I wanted to say thank you again, that worked.:wink:
Will peppy also work with fusiondSP, because at the moment there is no sound when both are running, or is there already a fix?
PS. If you click on my Avatar, you will find several skins for your resolution :crazy_face:
Hi. I’ve come late to this project. I’ve followed the thread as it’s gone on but not had the time to join in. I would now like to try it out.
I’ve re-read from the beginning but as the project has grown, I’m now un-certain of which steps are needed to actually get started.
Is it possible for someone to make a simple list of the necessary steps? Once up and running I can work things out for my specific needs.
I know that this looks as though I just want someone to do the work for me but I’ve spent a couple of days getting nowhere.
Thanks in advance for any help!
You only need to have your screen already installed
