All my skins are in this post, you see:
NAD-6100 (1280x400)
nad-6100 (1280x400).zip (334.9 KB)
The PioneerCT, Optonica, Pioneer Deck and Advance look pretty cool. Can you scale to 1280x800?
Thank you.
Andy
Hi Gelo5 - The Abrahamsen skin seems fine - The advance skin needle is not completely red, it has a blue secondary line next to each needle, hope you can see that from the pic?
Both are excellent additions to the growing collection…Thanks!
I have an waveshare 11.9 inch screen but the resolution is 320×1480
Is there something for that resolution ? I suck in Photoshop and don’t know how to make my own meters.
Hope somebody knows or can guide me , i have installed peppymeter but there is nothing with that resolution
I have 13 days to send that screen back
@bungie240
Check now (corrected)
@m4sta2k
custom_7 (1480x320).zip (235.3 KB)
Unpack
Copy the ALL folder to:
/data/plugins/miscellanea/peppy_screensaver/peppymeter
Set Scteensaver timeout - 10s
This is a trial - see if it works
The last one from me:
SPL Director MK2 (1280x400):
Original:
Modified for peppy:
SPL-Director=MK2 (1280x400).zip|attachment (831.5 KB)
Thank you but it does not work , i have copied everything as you said. The others start without problems but not custom_7 map.
Is the folder even loading, as I encountered similar issues with custom_2, custom_3,…
So now I’ve dropped everything in Custom_1
How do the others start? There is only 1 skin for testing.
Do you have such a folder?
custom_7 (1480x320)
And in folder 3 graphics and meters.txt ?
I have tried uninstalling peppymeter , putting it in another folder as suggested , meters is edited to the one but it still doesn’t work. What can I do ? Thank you for your help
I got it started but it looks like this
edit: Installed everything from scratch twice .
what happens is when I add the custom_7 folder and the 3 pictures pluss the meters text , it wont start, and it hangs. Something is wrong with that config meter file i think.
If I dont do anything the default meter folders works fine. but has the wrong resolution all of them.
Hi Everyone, I installed Volumio 3.251 & used the video by Andy to install PepperMeter Plugin. It was working great until I installed the FusionDsp Plugin. After installing FusionDsp the sound on Spotify stopped working & the PeppyMeter Plugin also stopped working. I fixed the spotify sound using the info in the description of Andy’s install video. Now my problem is I have the PeppyMeter plugin installed & Enabled but it is no longer working. I’ve tried disabling & enabling the plugin and restarted, I’ve reinstalled the plug-in a few times & even did a fresh Volumio install but as soon as I install FusionDsp it stops working all over again. Are you able to help me out? I really want to get this working with FusionDsp & spotify for a project I’m doing. I’m using a Raspberry Pi3b+ & waveshare 5.5" touchscreen with the touchscreen plugin installed & enabled. I also have a X400 V3.0 Dac/amp. This is the video I used to install:
You probably bought it on Alliexp. Provide a link to this monitor - I will look
And try:
type in userconfig.txt
hdmi_group=2
hdmi_mode=87
hdmi_cvt=1480 320 60 6 0 0 0
But first, replace the image files (2) and try
custom_7 (1480x320).zip (235.2 KB)
Hi @Gelo5 ,
I’ve searched for a tutorial on this options on userconfig.txt in volumio but couldn’t find much info (regarding HDMI for instance).
I understand that hdmi_cvt = 1480 320 60 might be resolution and refresh rate, but the 0s and the other settings you inserted I have no idea…
Is there any info regarding this options? One of the things I wish to try is to do, for instance, is to fix a 1080P resolution on a 4K monitor.
Thanks in advance.
BR,
Paulo
Thank you for your answers
By changing the config file in peppymeter folder as you see here
And restarting the peppymeter , it then shows up like this
We are a step closer to success
And the screen is original waveshare 11.9 bought from 11.9" IPS Kapasitiv Touchskjerm 320x1480, kompatibel med bl.a. RPi - Digital Impuls Oslo AS in Norway
Edit : after restarting screen width and info gets remowed and shows
And the screen goes back to
OK, try to overwrite everythingcustom_7 (1480x320).zip (243.7 KB)
Or delete the entry in config.txt
It is difficult to fix anything without a monitor
I think your monitor is 1680 not 1480
thank you for trying to help me, I appriciate it
My monitor is this one https://www.waveshare.com/wiki/11.9inch_HDMI_LCD
So after a clean install of everyting
I copy custom_7 folder to peppymeter
Try to start it
Everything hangs for some time. and nothing happens it does not start
i delete plugin, instlal plugin back again ,and start random folder thats allread installed , and then it works without problem
Something is wrong somewhere and I dont know what it can be the problem
for example if i add the custom_7 files to Wide folder , and edit the meters.txt , it starts but with wrong resolution, by editing config.txt widht and height to correct, it then shows correct .
One more thing. Set the data in userconfig.txt not in config.txt. Maybe it will work?
Write to @2aCD, he will surely help.
And my last (emergency) advice:
Copy to 1920x480 folder (closest to your resolution)
That worked !
I copied it to the 1920x480 folder and now it shows correct.
Now i just have to learn how to make my own meters. I would love to have some of the blue mcintosh dials
