I have a PI3 with Volumio3 and a 800x480 display (5.5" and not 7") and Peppymeter running not in random mode (I like a specific set of dials!) with cache enabled and I have this memory situation:
Hi massimogentilini
for a RPi3 with 1gb its better to deactivate the cache. The cache needs more free memory.
If you don’t need all different meters, reduce the number of meters for random mode with the list option. This also reduce the required memory.
Here’s a quick one. How can I easily see changes to the meters without rebooting? I figured it would be something like a service something restart. Currently, when i change and apply a different meter to sEe what it looks like, i need to reboot. Thank you.
I have a raspberry pi4 in a box with a 3.5 lcd with volumio layout attached to the rpi4. I would like to connect a 3.5 inch display for the PeppyMeter. I still have a nextion but I can’t handle it at all. are there any other options than buying a very expensive hdmi display to see peppy? is it possible to connect 2 displays to the 40pin at all?
Hi members, if you can please look into this and share your inputs as to how to resolve this issue –
I have 2 Volumio setup - One at the Living Room and One at the Office Room. Both the areas for display I am using a 4K TV.
Now the concern is - the Peppy Meter plugin for the Office room TV when starts cover the full screen where as the same plugin in my Living room covers not even the half of the screen.
I have shared the images below for everybody’s reference. Please suggest I need to make any changes in the Peppy meter folder of my Living room so that I can get the full screen like the office room.
