Have you read this?
As I wrote
I go to beginning of thread but on first post still 1.4.0
My fault, I’m too lazy to check post nr 7 :slight_smile: and thought that is striclty something new.
Thank you.
Fantastic work, visually stunning. Can you please re- upload your fantastic skins as the download links have expired.
I connected 10,4 Waveshare with 1600 x 720 res… but I found way to run it with another resolution peppy meters.
Here with 1024 x 600:
maybe it’s normal but I did it by accident and confirmed few times that it works. It gives more peppy meter LCD option.
it’s squeezing the layout a bit, working but not ideal.
Yes, but its depend what skin and resolution you choose, on first skin it is not a problem. Squeezing is because of proportions 1,7 to 2,2. In my opinion is better than visible screen without peppy meter
Which one?
@eMCZe
the first three points on post 7 are new in 1.4.1, the others in 1.4.0
new volumio image: version 3.616 installed.
peppymeter version 1.4.1
Philips TDA 1541A USB DAC.
7.9 inch Waveshare HDMI touch screen.
DSD native (separate pipe)
spotify integration on.
all okay.
Scherm­afbeelding 2024-02-22 om 20.32.04
Yes, believe it or not, I can read. .
Got it working on my HD Sony TV, looks AMAZING.
Last question, how do I get rid of the Bar at the bottom of the screen, the one that shows “Stop” “Next Track” etc?
Many thanks
by using the correct resolution in Peppy meter. seems your height is incorrect.
The loaded template does not match your screen resolution.
Adjust the skin to your resolution - you used a skin with a lower resolution than your monitor (or you have a monitor with an unusual resolution)
Edit:
@Wheaten
We’re writing at the same time again
yeah the moment I pressed reply, you’re comment showed below it.
Many thanks
Where do I adjust the resolution parameters.
I am using a 75" TV
Cheers
Size doesn’t matter (ONLY in this case) :ok_hand:
Enter into userconfig.txt:
hdmi_group=2
hdmi_mode=87
hdmi_cvt 1920 1080 60 3 0 0 0
hdmi_drive=2
and force the TV to have this resolution. Use 1920x1080 skins
is it time to look at vector based meters because of scalability?
or is this not possible with peppy?
1600*720 “Test” Skin work fine with v 1.4.0
Forgive me if answered 1000 times already, how do I exacty add specific meters. Im assuming via filezilla however how do I dump all thee specific ones for a specific resolution etc? TY
