eureka!!! thanks so much guys for your patience
I have install the peppy meter plugin. The issue I am facing is there is no display when the peppy meter suppose to come on the screen. I have choose all available resolution on the option but still totally no display. Not sure what might be the issue
Well one issue I see, no information is given to even find a way to support you.
For starters:
- What is your device?
- Which screen are you using?
- Is Volumio UI showing?
- What version of Volumio are you using and don’t respond back with “the latest”?
- Which plugins have been installed?
And what was it for?![]()
- Please remove Google touch, we have seen more issues with the Volvo S90 version.
- Have you tried to connect the S90 to the Isle of man?
- Have you tried to connect the LG to HDMI3, while rotating it sideways and click you heals?
If above won’t fix it, park the S90 around an oak!
Hello, I would like to have a suitable skin for my 2560 x 720 display. Would it work with this resolution?
I thank you for the support.
preferably this one
Max 1920x1080
Otherwise: set Peppymeter to 1280x800 and show what is on the screen (photo).
Or you can create your own template.
The first 2 are very easy to resize then you only need to adapt the meters.txt file.
Instructions can be found here:
It’s a shame, unfortunately I’m not the programmer who can do that
You don’t need to be a programmer to do this, all that’s needed is the capability to type integers and look at your screen.
all instructions have been documented and should be very easy to follow/understand.
Since you’re the only one with this format, assistance will be troublesome.
There is always someone who is first.
This display is the perfect size for a 43 inch device, that’s why
I’ll say it again, take a photo when you run Peppymeter with a different resolution. We’ll do something.
oh sorry, I misunderstood that
Here it is, removed the tree though… ![]()
Great, I like photos like this. Is this your car? Mine is white and already repaired. ![]()
@Rue
Try this:
2560x720_Gold Test.zip (373.1 KB)
COPY TO /data/plugins/miscellanea/peppy_screensaver/peppymeter/custom_4 (1920x1080)
that is the result
I added the meter.txt and copied the files to the specified directory
thank you for the quick delivery
Hm, try adding a folder custom_7 (2560x720) and copy everything to it
2560x720_Gold Test2.zip (373.1 KB)
I did that,
now peppymeter no longer starts a template, with no setting / resolution ![]()
