i got error during install socketIO-Client in peppymeter script-
Volumio release is 2.907
volumio@volumio:~$ python3 -m pip install socketIO-client
Downloading/unpacking socketIO-client
Downloading socketIO-client-0.7.2.tar.gz
Running setup.py (path:/tmp/pip-build-o4u7_64o/socketIO-client/setup.py) egg_info for package socketIO-client
warning: no files found matching '*.html'
warning: no files found matching '*.js'
warning: no previously-included files matching '*.pyc' found anywhere in distribution
Downloading/unpacking requests>=2.7.0 (from socketIO-client)
Downloading requests-2.26.0-py2.py3-none-any.whl (62kB): 62kB downloaded
Cleaning up...
Exception:
File "/usr/lib/python3/dist-packages/pkg_resources.py", line 2595, in _dep_map
return self.__dep_map
File "/usr/lib/python3/dist-packages/pkg_resources.py", line 2457, in __getattr__
raise AttributeError(attr)
AttributeError: _DistInfoDistribution__dep_map
During handling of the above exception, another exception occurred:
File "/usr/lib/python3/dist-packages/pip/basecommand.py", line 122, in main
status = self.run(options, args)
File "/usr/lib/python3/dist-packages/pip/commands/install.py", line 290, in run
requirement_set.prepare_files(finder, force_root_egg_info=self.bundle, bundle=self.bundle)
File "/usr/lib/python3/dist-packages/pip/req.py", line 1266, in prepare_files
req_to_install.extras):
File "/usr/lib/python3/dist-packages/pkg_resources.py", line 2401, in requires
dm = self._dep_map
File "/usr/lib/python3/dist-packages/pkg_resources.py", line 2597, in _dep_map
self.__dep_map = self._compute_dependencies()
File "/usr/lib/python3/dist-packages/pkg_resources.py", line 2621, in _compute_dependencies
parsed = next(parse_requirements(distvers))
File "/usr/lib/python3/dist-packages/pkg_resources.py", line 2721, in parse_requirements
"version spec")
File "/usr/lib/python3/dist-packages/pkg_resources.py", line 2686, in scan_list
raise ValueError(msg, line, "at", line[p:])
ValueError: ('Expected version spec in', 'charset-normalizer ~=2.0.0', 'at', ' ~=2.0.0')
Storing debug log for failure in /home/volumio/.pip/pip.log
Hi @fabio323ti
the problem is, peppy.player has released a new update of PeppyMeter with many changes for us to implement it better in Volumio. So I don’t more change the original code. Please wait until I publish a new version of install script. I’m at time on Vacation and start the work on next week.
At time only the previous version of PeppyMeter works with my installer. You can download the previous version of PeppyMeter from git and remark the gitclone command in my installer and run the install_PeppyMeter again. But a better way is to wait a little bit
Best regards
2aCD
Running Volumio 3.080 and installed PeppyMeter using the script for both peppyalsa and peppymeter. However, after a successful install and a reboot, I am unable to play any audio. I have editing the asound.conf in both peppyalsa folder and /etc/asound.conf w/ out success. Should I wait for the new script or am I missing something trivial?
Card 2 is what I would like to use, this was working until I toggled DACs.
Not a big deal I can wait until next week. Question, is there a way to roll back from the cli to an older version w/ out having to pull the flash and re-flash?
I’m done now with the new version of PeppyMeter integration. Please start from a new fresh installation. Thats important for a sucessfully installation. Please download all components again from here:
First of all thank you very much for this fantastic plug-in. I installed the old version three weeks ago and it worked perfectly. I enjoyed it very much! Then I got errors when I tried to re-install last week. But knowing that a new install version is coming, I waited patiently for you to finish your vacation. Yesterday I got this new install_peppy version and I installed immediately with Volumio v.2.873 upgraded to 2.907. Everything went fine until the last bit.
My screen is 800x480, and I selected everything as said with custom_800. It didn’t work.
When you d9woaded the custom folder and unzip it just make sure that you enter in the folder and copy that folder…
1.Custom_800 >>>2.Custom_800>>>pictures. Copy the second folder not complete…
I hope I explained correctly…
